Ciao Denis,
Grazie per la risposta rapida.
Guardando i log, ho effettivamente degli avvisi; potrebbe essere correlato alla parte SSL?
PS: Ho sostituito il nome del server con wapt.intserver.net, ma per il resto tutto il resto è intatto.
2025-02-05 13:40:20,100 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:40:20,100 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:40:21,061 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:21,061 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:40:59,412 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:41:59,465 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
Client ('127.0.0.1', 64074) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64076) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64078) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:42:59,567 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:43:59,578 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:43:59,660 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:44:22,531 [wapttasks WaptTaskManager 7160] INFO Add task Mise à jour de la liste des paquets disponibles to queue
2025-02-05 13:44:22,544 [wapttasks WaptTaskManager 7160] INFO Running task Mise à jour de la liste des paquets disponibles created by SCHEDULER
Get packages index from [<WaptRepo http://wapt-foch-lille.repo.intserver.net/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\sv22dc-003377.mydom.local.crt>, <WaptHostRepo https://wapt.intserver.net/wapt-host for host_id sv22dc-003377.mydom.local >]
2025-02-05 13:44:24,794 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:44:24,794 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:44:25,940 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:25,940 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:44:59,740 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:45:59,806 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:46:59,855 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:47:59,915 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:48:59,925 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
Inizialmente credo di aver capito che non riesce a trovare un host per quel nome sul server (nel frattempo il nome del server non è cambiato); è lungo 13 caratteri se non contiamo il nome di dominio
O ho capito male oppure sta cercando di usare HTTP con il server che usa HTTPS?
Per quanto riguarda il nome, in questo caso samAccountName AD e il nome locale sono gli stessi
Di seguito il contenuto del file wapt-get.ini direttamente sul client
[global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
repo_url=https://wapt.intserver.net/wapt
wapt_server=https://wapt.intserver.net
verify_cert=0
use_fqdn_as_uuid=1
allow_remote_reboot=1
allow_remote_shutdown=1
use_repo_rules=True
[default_global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
hiberboot_enabled=0
verify_cert=0
use_fqdn_as_uuid=1
[waptwua]
enabled=True
default_allow=True
install_at_shutdown=True
download_scheduling=12h
[default_waptwua]
- wapt3.png (10,12 KB) Visualizzato 17291 volte
- wapt4.png (14,95 KB) Visualizzato 17291 volte
- waptt.png (18,6 KB) Visualizzato 17291 volte
