Dopo aver tentato di installare il pacchetto tis-phylogene-lycee (versione 2.7.6.1-3) su diverse workstation, stiamo riscontrando difficoltà (arresto anomalo all'avvio, messaggio di errore e perdita di memoria seguita da arresto anomalo) quando i collegamenti sul desktop e nel menu Start non popolano la directory di lavoro ("Avvia in") con "C:\Program Files (x86)\Phylogène Lycée\Programmes".
Questi bug non sono più evidenti quando questo valore è presente.
Di seguito trovate il file setup.py con la correzione:
Grazie in anticipo per il vostro aiuto
JM
# This file is part of WAPT Enterprise
# All right reserved, (c) Tranquil IT Systems 2024
# For more information please refer to
# https://wapt.tranquil.it/store/licences.html
app_name = "Phylogène Lycée"
app_dir = makepath(programfiles32, app_name)
work_path = makepath(app_dir, "Programmes")
app_path = makepath(work_path, "Phylo.exe")
icon_path = app_path
audit_version = False
def get_installed_version(app_path):
return get_file_properties(app_path).get("FileVersion", "")
# Declaring local variables
zip_name = glob.glob(f"Phylogene-Lycee-2021.zip")[0]
unzip_dest = "."
unzipped_dir = "Phylogène-Lycée-2021"
# Removing old portable app
old_app_dir = makepath(programfiles32, "Phylogene-lycée")
if isdir(old_app_dir) and app_dir != old_app_dir:
remove_tree(old_app_dir)
unregister_uninstall(app_name)
# Installing software
if isdir(app_dir) and force:
remove_tree(app_dir)
mkdirs(app_dir)
print("Extracting: %s to: %s" % (zip_name, app_dir))
unzip(zip_name, unzip_dest)
copytree2(unzipped_dir, app_dir, onreplace=default_overwrite)
# Creating custom shortcuts
create_desktop_shortcut(app_name, target=app_path, wDir=work_path)
create_programs_menu_shortcut(app_name, target=app_path, wDir=work_path)
def audit():
# Auditing software
audit_status = "OK"
installed_version = get_installed_version(app_path)
if Version(installed_version) < Version(control.get_software_version()) and audit_version:
print("%s is installed in version (%s) instead of (%s)" % (app_name, installed_version, control.get_software_version()))
audit_status = "WARNING"
elif isdir(app_dir) and not dir_is_empty(app_dir):
print("%s (%s) is installed" % (app_name, installed_version))
audit_status = "OK"
print("%s is not installed" % app_name)
audit_status = "ERROR"
return audit_status
# Uninstalling software
if isdir(app_dir):
# Removing shortcuts
remove_desktop_shortcut(app_name)
remove_programs_menu_shortcut(app_name)
