Re: [RISOLTO] Crittografia delle password Wapt
Pubblicato: 20 luglio 2018 - 10:27
Devi posizionare lo script nella cartella di installazione di wapt.
Contattaci
su https://forum.tranquil.it/
def isGroup(myPackage):
Renvoie True si le paquet est un paquet groupe de l'AD.
:param myPackage: nom du paquet à tester.
:return boolean: True si myPackage appartient à groupPackages, False si non.
:exemple:
> isGroup('lot1')
True
> isGroup('tis-java8')
False
groupPackages = {'lot1','lot2','lot3','lot4'}
for group in groupPackages:
if group == myPackage:
return True
return False
def haveGroup(depends):
Renvoie true si la ligne de dépendance en paramètre contient un des groupes.
:param depends: ligne de dépendance au format "dependance1,dependance2,..."
:return boolean: True si il y a un groupe False si non.
:exemple:
> haveGroup('tis-chrome, tis-microsoft-office, lot1')
True
> haveGroup('tis-chrome')
False
if not depends :
return False
else :
packages = depends.split(',')
for p in packages:
if isGroup(p):
return True
return False
def main(get_group):
Repartie les clients WAPT dans différents groupes (groupes AD).
:param get_group: fonction qui renvoie le nom du package group
# const
USER = 'admin'
URL_SERVER = '**********'
RESULT_LIMIT = 1500
TEMP_DIR_ROOT = 'c:/temp/*******'
PATH_TO_CONFIGFILE = r'C:/Users/administrateur/AppData/Local/waptconsole/waptconsole.ini'
FORCE = False
remove_tree(TEMP_DIR_ROOT)
myWapt = Wapt(config_filename = PATH_TO_CONFIGFILE)
mycrt = r"****************"
credentials_url = waptguihelper.login_password_dialog('admin loggin', URL_SERVER, USER, '')
passwd_private_key = waptguihelper.key_password_dialog('Password for private key',mycrt, '')
USER = credentials_url['user']
PASSWORD = credentials_url['password']
PASSWORD_KEY = passwd_private_key['keypassword']
data = json.loads(wgets('https://%s:%s@%s/api/v1/hosts?limit=%s' % (USER, PASSWORD, URL_SERVER, RESULT_LIMIT)))
uuid, depends, fqdn, tmpdir = '','','',''
if FORCE:
print("Force : True")
for value in data['result']:
uuid = value.get('uuid')
depends = value.get('depends')
fqdn = value.get('computer_fqdn')
if not haveGroup(depends) or FORCE:
group_name = get_group(fqdn)
tmpdir = makepath(TEMP_DIR_ROOT, uuid)
myWapt.edit_host(uuid, target_directory = tmpdir, append_depends = group_name)
myWapt.build_upload(r'%s'%tmpdir, private_key_passwd = PASSWORD_KEY, wapt_server_user = USER, wapt_server_passwd = PASSWORD)
print("%s (%s) ---> %s"%(uuid,fqdn,group_name))
if __name__ == "__main__":
main(get_group = mafonctiongetGroup)Codice: Seleziona tutto
def toSiteName(computer_fqdn):
Renvoie le nom du site en fonction du host name.
:param computer_fqdn: full hostname d'un poste client.
:return string: nom du site en majuscule
host = computer_fqdn.split('.')[0][0:4]
return host.upper()
def getGroup(fqdn):
Renvoie le groupe en fonction du nom de l'hote
site_name = toSiteName(fqdn)
group_name = alias_groupe.get(switcher.get(site_name, 0), 'hors-lot')
return group_name
alias_groupe = {
0:'hors-lot'
1:'lot1',
2:'lot2',
3:'lot3'
switcher = {
'X000':1
'X001':2
'X002':1
'Y010':3
