Pagina 2 di 2
Re: Elenco dei pacchetti e del loro stato
Pubblicato: 9 ottobre 2026 - 14:42
di Mikael S
Un piccolo aggiornamento dopo tutto questo tempo. Da allora abbiamo ottenuto ottimi risultati
import datetime
import itertools
import json
import re
import winreg
from contextlib import suppress
# Dictionnaire package wapt => nom de l'application en format regex
dict_package_app = {
    "tis-adobereader" : r"Adobe Acrobat \(64-bit\)",
    "tis-affinity" : "Affinity",
    "tis-affinity-designer" : "Affinity Designer",
    "tis-affinity-photo" : "Affinity Photo",
    "tis-affinity-publisher" : "Affinity Publisher",
    "tis-affinity-designer-2" : "Affinity Designer 2",
    "tis-affinity-photo-2" : "Affinity Photo 2",
    "tis-affinity-publisher-2" : "Affinity Publisher 2",
    "tis-anaconda3": "Anaconda3 [0-9].*",
    "tis-audacity" : "Audacity [0-9.]+",
    "tis-bcu-bios-hp": "HP BIOS Configuration Utility",
    "tis-beyondtrust-rs" : "BeyondTrust Jump Client - pmad.unistra.fr",
    "tis-calculator" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsCalculator.*",
    "tis-cartes" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsMaps_.*",
    "tis-chrome" : "Google Chrome",
    "tis-disable-telemetry" : "Microsoft Update Health Tools",
    "tis-element" : "Element",
    "tis-extensions-de-support-web" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WebMediaExtensions_.*",
    "tis-firefox" : r"Mozilla Firefox \(x(86|64) [a-zA-Z -]+\)",
    "tis-firefox-esr" : r"Mozilla Firefox ESR \(x(86|64) [a-zA-Z -]+\)",
    "tis-forticlient-vpn" : "FortiClient VPN",
    "tis-foxit-pdfeditor-11" : "Foxit PDF Editor",
    "tis-foxit-pdfeditor-12" : "Foxit PDF Editor",
    "tis-foxit-pdfeditor-13" : "Foxit PDF Editor",
    "tis-foxit-pdfeditor-14" : "Foxit PDF Editor",
    "tis-foxit-pdfeditor-2024" : "Foxit PDF Editor",
    "tis-gimp" : "GIMP [0-9-.]+",
    "tis-googleearth" : "Google Earth Pro",
    "tis-glpi-agent" : "GLPI Agent [0-9.]+",
    "tis-keepassxc" : "KeePassXC",
    "tis-libreoffice-fresh" : "LibreOffice [0-9.]+",
    "tis-microsoft-windowsalarms" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsAlarms.*",
    "tis-microsoft-edge" : "Microsoft Edge(| Update)",
    "tis-microsoft-photos" : r"C:\\Program Files\\WindowsApps\\Microsoft\.Windows\.Photos.*",
    "tis-microsoft-soundrecorder" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsSoundRecorder.*",
    "tis-microsoft-stickynotes" : r"C:\\Program Files\\WindowsApps\\\Microsoft\.MicrosoftStickyNotes.*",
    "tis-microsoft-teams" : "Teams Machine-Wide Installer",
    "tis-microsoft-windows-camera"  : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsCamera.*",
    "tis-naps2" : "NAPS2",
    "tis-windows-notepad" : r"C:\\Program Files\\WindowsApps\\Microsoft\.WindowsNotepad.*",
    "tis-onlyoffice-desktop" : r"ONLYOFFICE [0-9.]+ \(x64\)",
    "tis-oracle-java8-jre-free" : "Java 8 Update [0-9]+(| x64 bit)",
    "tis-paint.net" : "(paint.net|Paint.NET)",
    "tis-paint-3d" : r"C:\\Program Files\\WindowsApps\\Microsoft\.MSPaint.*",
    "tis-pdf24-creator" : "PDF24 Creator",
    "tis-putty" : r"PuTTY release [0-9.]+( \(64-bit\)|)",
    "tis-rtools" : "Rtools [0-9 ().-]+",
    "tis-seafile" : "Seafile [0-9.]+",
    "tis-sphinx-iq3" : "SphinxIQ3",
    "tis-spyder" : "Spyder [0-9]",
    "tis-stormshield-vpn" : "Stormshield SSL VPN Client",
    "tis-teamviewer" : "TeamViewer( [0-9]+|)",
    "tis-thunderbird" : "Mozilla Thunderbird .*",
    "tis-vcredist2015-2022" : r"Microsoft Visual C\+\+ (2015-(2019|2022) Redistributable \(x(86|64)\)|(2019|2022) X(86|64) (Additional|Minimum) Runtime) - [0-9.]+",
    "tis-wazo" : "Wazo Desktop",
    "tis-webex" : "(Webex|Cisco Webex Meetings)",
    "tis-webview2" : "Microsoft Edge WebView2 Runtime",
    "tis-withsecure" : "WithSecure™ Client Security Premium",
    "tis-zoom" : r"Zoom Workplace \(64-bit\)"
# Liste des appx gérées
appx = [
    "tis-calculator",
    "tis-cartes",
    "tis-extensions-de-support-web",
    "tis-microsoft-windowsalarms",
    "tis-paint-3d",
    "tis-microsoft-photos",
    "tis-microsoft-soundrecorder",
    "tis-microsoft-stickynotes",
    "tis-microsoft-windows-camera",
json_file = r"C:\Windows\wapt\autofix.json"
    generate_json()
def audit():
    if not isfile(json_file):
        generate_json()
    with open(json_file) as file:
        status = json.load(file)
    return_value = "OK"
    packages_installed = set() # Contient la liste des paquets installés pour purge le json ensuite
    for wapt_installed_package in WAPT.waptdb.installed_status(include_errors=True):
        packages_installed.add(wapt_installed_package['package'])
        # Gestion des installation en erreur si le paquet est déclaré dans dict_package_app
        # Tentative de purge de la des anciennes installations de la base de registre
        if wapt_installed_package['install_status'] == "ERROR" and wapt_installed_package['package'] in dict_package_app:
            if status['install'].get(wapt_installed_package['package'], False):
                print(f"Réparation de l'installation du paquet {wapt_installed_package['package']} déjà tenté")
                return_value = "ERROR"
                print(f"Tentative de réparation de l'installation du paquet {wapt_installed_package['package']}")
                if WAPT.waptserver.available():
                    status['install'][wapt_installed_package['package']] = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
                    delete_key("Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall", 'DisplayName', dict_package_app[wapt_installed_package['package']])
                    delete_key("Software\\WOW6432Node\\Microsoft\\Windows\\CurrentVersion\\Uninstall", 'DisplayName', dict_package_app[wapt_installed_package['package']], winreg.KEY_WOW64_32KEY)
                    delete_key("SOFTWARE\\Classes\\Installer\\Products", 'ProductName', dict_package_app[wapt_installed_package['package']])
                    delete_key("SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Appx\\AppxAllUserStore\\Applications", 'Path', dict_package_app[wapt_installed_package['package']])
                    try:
                        WAPT.install(wapt_installed_package['package'], force=True)
                    except:
                        print(f"Erreur d'installation de {wapt_installed_package['package']}")
                        if not status['wmi'] and WAPT.is_installed("tis-script-cache-wmi-reparer") and wapt_installed_package['package'] in appx:
                            print('Tentative de réparation du cache wmi')
                            WAPT.install("tis-script-cache-wmi-reparer", force=True)
                            status['wmi'] = True
                            print('Une tentative sera faite au prochain audit')
                            del status['install'][wapt_installed_package['package']]
                    if return_value != "ERROR":
                        return_value = "WARNING"
                    print("Serveur WAPT non joignable - une tentative sera faite au prochain audit")
        # Si le paquet n'est pas en erreur, on le retire du json s'il existe
        elif status['install'].get(wapt_installed_package['package'], False) and wapt_installed_package['install_status'] == "OK":
        # Gestion des audit en erreur
        # Tentative d'une installation forcée
        if wapt_installed_package['last_audit_status'] == "ERROR" and wapt_installed_package['package'] not in ("tis-audit-battery", "tis-autofix-installation", "tis-pending-reboot-notification"):
            if status['audit'].get(wapt_installed_package['package'], False):
                print(f"Réparation de l'audit du paquet {wapt_installed_package['package']} déjà tenté")
                print(f"Tentative de réparation de l'audit du paquet {wapt_installed_package['package']}")
                    status['audit'][wapt_installed_package['package']] = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
                    try:
                    except:
        elif status['audit'].get(wapt_installed_package['package'], False):
            del status['audit'][wapt_installed_package['package']]
    # Purge des anciennes tentative si le paquet n'est plus sur la machine
    for wapt_installed_package in status['install'].copy():
        if wapt_installed_package not in packages_installed:
            del  status['install'][wapt_installed_package]
    for wapt_installed_package in status['audit'].copy():
            del status['audit'][wapt_installed_package]
    # Réinitialisation du status wmi si plus aucune appx problématique
    appx_en_erreur = False
    if any(package in appx for package in status['install']):
        appx_en_erreur = True
    if not appx_en_erreur:
        status['wmi'] = False
    with open(json_file, 'w') as autofix:
        json.dump(status, autofix)
    return return_value
    if isfile(json_file):
        remove_file(json_file)
def generate_json():
    if not isdir(r'C:\Windows\wapt'):
        mkdirs(r'C:\Windows\wapt')
    status = {}
    status['install'] = {}
    status['audit'] = {}
def delete_key(key_uninstall, key_value, key_search, access=winreg.KEY_WOW64_64KEY):
    for subkey in subkeys(key_uninstall, access):
        appkey = winreg.OpenKey(winreg.HKEY_LOCAL_MACHINE, rf"{key_uninstall}\{subkey}", 0, winreg.KEY_READ | access)
        key_find = reg_getvalue(appkey, key_value, '')
        if re.match(f"^{key_search}$", key_find):
            print(rf'Suppression clé {key_uninstall}\{subkey}')
            registry_deletekey(winreg.HKEY_LOCAL_MACHINE, key_uninstall, subkey, force=True, recursive=True)
def subkeys(path, access=winreg.KEY_WOW64_64KEY, hkey=HKEY_LOCAL_MACHINE,):
    with suppress(WindowsError), winreg.OpenKey(hkey, path, 0, winreg.KEY_READ | access) as k:
        for i in itertools.count():
            yield winreg.EnumKey(k, i)
Per le applicazioni, un meccanismo di fallback può talvolta essere utile quando la cache WMI è danneggiata, ma in realtà viene usato raramente.
In wapt è presente una funzione per ripristinare la cache, ma restituisce solo un errore.
Ecco un codice funzionante
import glob
import time
    if force:
        # https://woshub.com/wmi-troubleshooting/
        # arret des services associé à winmgmt
        set_service_start_mode("winmgmt", "Disabled")
        if service_installed('winmgmt') and service_is_running ('winmgmt'):
            run('cmd /c net stop winmgmt /y')
        print('Commande : winmgmt /resetrepository')
        run('cmd /C winmgmt /resetrepository')
        print('Commande : winmgmt /resyncperf')
        run('cmd /C winmgmt /resyncperf')
        print(r'Commande : regsvr32 /s %systemroot%\system32\scecli.dll')
        run(r'cmd /C regsvr32 /s %systemroot%\system32\scecli.dll')
        print(r'Commande : regsvr32 /s %systemroot%\system32\userenv.dll')
        run(r'cmd /C regsvr32 /s %systemroot%\system32\userenv.dll')
        for file in glob.glob(r'c:\windows\system32\wbem\*.dll'):
            print(rf'Commande : regsvr32 /s {file}')
            run_notfatal(rf'cmd "/C regsvr32 /s {file}"')
        for file in glob.glob(r'c:\windows\system32\wbem\*.mof'):
            if "uninstall" not in file.lower():
                print(rf'Commande : mofcomp {file}')
                run_notfatal(rf'cmd "/C mofcomp {file}"')
        for file in glob.glob(r'c:\windows\system32\wbem\*.mfl'):
        if service_installed('winmgmt') and not service_is_running ('winmgmt'):
            print('Relance du service winmgmt')
            service_start('winmgmt')
        set_service_start_mode("winmgmt", "Auto")
        print('Commande : wmiprvse /regserver')
        run('cmd /C wmiprvse /regserver')
        print(r'Commande : gpupdate /force /target:computer"')
        run(r'gpupdate /force /target:computer"')
def audit():
    winmgmt = run('winmgmt /verifyrepository')
    print(winmgmt)
    if "WMI EST cohérent" in winmgmt:
        retour = "OK"
    elif "WMI repository is consistent" in winmgmt:
        retour = "OK"
        retour = "ERROR"
    try:
        get_powershell_str('get-printer')
        get_powershell_str('Get-BitLockerVolume -MountPoint c:')
        get_powershell_str('Get-AppXProvisionedPackage -Online')
    except:
        print('Erreur WMI détectée')
        retour = "ERROR"
    return retour
