Pagina 1 di 1
[RISOLTO] Microsoft Office 2019
Pubblicato: 20 agosto 2019 - 14:18
di agatoi
Ho un problema di distribuzione con un pacchetto Microsoft Office 2019.
Su un computer Windows 10 Education (licenza attivata), durante l'installazione il computer visualizza un messaggio di errore:
installing Office 2019Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptsasqmr\setup.py", line 21, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3625, in run
    return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args))
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run
CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.
Output:
Output:
Risultato del comando wapt-get install -l debug aiz-msoffice2019:
C:\Windows\system32>wapt-get install -l debug aiz-msoffice2019 > c:\wapt_office2019.txt
2019-08-20 13:46:52,211 DEBUG Default encoding : ascii
2019-08-20 13:46:52,211 DEBUG Setting encoding for stdout and stderr to cp850
2019-08-20 13:46:52,259 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python27.zip', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\plat-win', 'C:\\Program Files (x86)\\wapt\\lib\\lib-tk', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\pywin32-223-py2.7-win32.egg']
2019-08-20 13:46:52,259 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2019-08-20 13:46:52,259 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2019-08-20 13:46:52,275 DEBUG Thread 2848 is connecting to wapt db
2019-08-20 13:46:52,290 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo global auth        2019-08-20 13:46:52,290 DEBUG Thread 2848 is connecting to wapt db
2019-08-20 13:46:52,290 DEBUG DB Start transaction
2019-08-20 13:46:52,290 DEBUG DB commit
2019-08-20 13:46:52,290 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo wapt auth
2019-08-20 13:46:52,305 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo wapt-host auth        2019-08-20 13:46:52,305 INFO User Groups:[]
2019-08-20 13:46:52,305 DEBUG WAPT base directory : C:\Program Files (x86)\wapt
2019-08-20 13:46:52,305 DEBUG Package cache dir : C:\Program Files (x86)\wapt\cache
2019-08-20 13:46:52,305 DEBUG WAPT DB Structure version;: 20190606
2019-08-20 13:46:52,305 DEBUG Checking if old install in progress
2019-08-20 13:46:52,555 DEBUG reset stalled install_status in database
2019-08-20 13:46:52,586 DEBUG Loading ssl context with cert C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.crt and key C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem                                                       2019-08-20 13:47:04,305 INFO   Use cached package file from C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt
2019-08-20 13:47:15,976 DEBUG Stores cert chain check in cache
2019-08-20 13:47:15,993 DEBUG Downloaded : {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\aiz-msoffice2019_2019-4_x64.wapt'], 'errors': [], 'packages': [PackageEntry(u'aiz-msoffice2019',u'2019-4' architecture=u'x64')]}                                      2019-08-20 13:47:15,993 INFO Register start of install C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt as user superuser to local DB with params {}        2019-08-20 13:47:15,993 INFO Interactive user:superuser, usergroups []
2019-08-20 13:47:27,430 INFO Status : Installing package aiz-msoffice2019 version 2019-4 ...
2019-08-20 13:47:27,430 DEBUG DB Start transaction
2019-08-20 13:47:27,430 DEBUG DB commit
2019-08-20 13:47:27,444 DEBUG DB Start transaction
2019-08-20 13:47:27,444 DEBUG DB commit
2019-08-20 13:47:27,476 INFO Control data for package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt verified by certificate SSLCertificate cn=srvwapt.stemarie-aizenay.fr        2019-08-20 13:47:27,476 INFO Installing package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt
2019-08-20 13:47:27,476 INFO Unzipping package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt to directory c:\users\superu~1\appdata\local\temp\waptu5srkc        2019-08-20 13:48:11,522 INFO Package has a setup.py, code signing certificate is required.
2019-08-20 13:48:11,522 DEBUG Certificate {'countryName': u'FR', 'commonName': u'srvwapt.stemarie-aizenay.fr'} is trusted by root CA srvwapt.stemarie-aizenay.fr        2019-08-20 13:48:11,522 DEBUG Checking signature with SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:11,522 DEBUG OK with SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:11,522 INFO Package issued by {'countryName': u'FR', 'commonName': u'srvwapt.stemarie-aizenay.fr'}
2019-08-20 13:48:29,365 INFO Unzipped files verified by certificate SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:29,365 DEBUG Removing existing persistent dir C:\Program Files (x86)\wapt\private\persistent\fe8904e7-33ea-416b-a450-c6fb2d43344d        2019-08-20 13:48:29,365 INFO   sourcing install file c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py
2019-08-20 13:48:29,365 DEBUG Import source c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py as __waptsetup_2u8375y4xr__
2019-08-20 13:48:29,395 INFO Install parameters : {}
2019-08-20 13:48:29,395 DEBUG DB Start transaction
2019-08-20 13:48:29,395 DEBUG DB commit
2019-08-20 13:48:29,427 INFO   executing install script
2019-08-20 13:48:29,427 DEBUG DB Start transaction
2019-08-20 13:48:29,427 DEBUG DB commit installing Office 2019
2019-08-20 13:48:30,927 INFO Run "setup.exe /configure ProPlus2019.xml"
2019-08-20 13:49:57,532 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.        Output:: Traceback (most recent call last): File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt exitstatus = setup.install()        File "c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py", line 21, in install run(cmd,timeout=1200,accept_returncodes=[1641,3010,0]) File "C:\Program Files (x86)\wapt\common.py", line 3625, in run        return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args)) File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run raise CalledProcessErrorOutput(proc.returncode,cmd,''.join(output))        CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.Output:        2019-08-20 13:49:57,532 DEBUG Cleaning package tmp dir
2019-08-20 13:49:57,766 DEBUG DB Start transaction
2019-08-20 13:49:57,766 DEBUG DB commit
2019-08-20 13:49:57,782 DEBUG DB Start transaction
2019-08-20 13:49:57,782 DEBUG DB commit
2019-08-20 13:49:57,799 DEBUG DB Start transaction
2019-08-20 13:49:57,799 DEBUG DB commit
2019-08-20 13:49:57,861 DEBUG Removing module: __waptsetup_2u8375y4xr__, refcnt: 4
2019-08-20 13:49:57,877 DEBUG Checking availability of host packages "[PackageEntry(u'p-salle-prof-01.stemarie-aizenay.local',u'1' )]"
2019-08-20 13:49:57,877 DEBUG Checking if p-salle-prof-01.stemarie-aizenay.local(=1) is installed/outdated
2019-08-20 13:49:57,891 DEBUG store status in DB
2019-08-20 13:49:57,891 DEBUG DB Start transaction
2019-08-20 13:49:57,891 DEBUG DB commit
2019-08-20 13:49:57,907 INFO Status :
2019-08-20 13:49:57,907 DEBUG DB Start transaction
2019-08-20 13:49:57,907 DEBUG DB commit
2019-08-20 13:49:57,924 CRITICAL Package aiz-msoffice2019 [x64_fr_PROD] not installed due to errors : CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.                                                               Output: Traceback (most recent call last): File "<string>", line 1407, in <module> File "<string>", line 542, in main File "C:\Program Files (x86)\wapt\common.py", line 4850, in install        force=force File "C:\Program Files (x86)\wapt\common.py", line 3929, in install_waptraise e        setuphelpers.CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113
Il file setup.py:
#Marche pas
uninstallkey = ["ProPlus2019Volume - fr-fr"]
uninstallstring='"C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    def killsoft():
      for soft in ("WINWORD.EXE","POWERPNT.EXE","EXCEL.exe","MSPUB.EXE","MSACCESS.EXE","INFOPATH.EXE","lync.exe","ONENOTE.EXE","OUTLOOK.EXE","ONENOTEM.EXE","MSOSYNC.EXE","GROOVE.EXE"):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    softname = "Microsoft Office Professional Plus 2019 - fr-fr"
    print("installing Office 2019")
    cmd = "setup.exe /configure ProPlus2019.xml"
    killsoft()
    check_installed_out = installed_softwares(softname)
    if not check_installed_out:
        error("End audit did not find the software.")
    cmd='"C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    run(cmd)
    if os.path.isdir("C:\Program Files\Microsoft Office"):
        shutil.rmtree("C:\Program Files\Microsoft Office")
Da notare che l'implementazione di Wapt con lo stesso setup.py è andata piuttosto bene anche in un'altra struttura dove mi trovo anch'io.
Riguardo a: Microsoft Office 2019
Pubblicato: 21 agosto 2019 - 09:58
di Gaetan
l'ordine
Funziona in un prompt dei comandi?
Pubblicato: 21 agosto 2019 - 16:43
di agatoi
Certamente, l'ho usato diverse volte senza problemi.
Tuttavia, ho deciso di utilizzare un metodo diverso da Wapt per distribuire Office. L'ho integrato in un'immagine FOG e ho distribuito quell'immagine.
Pubblicato: 22 agosto 2019 - 09:13
di Gaetan
Quando si tenta di modificare il comando cmd in
r'"setup.exe" /configure ProPlus2019.xml'
Cambia qualcosa?
[RISOLTO] Re: Microsoft Office 2019
Pubblicato: 29 agosto 2019 - 11:02
di agatoi
scusa per il ritardo.
Ora funziona molto meglio.
Grazie!
Pubblicato: 30 agosto 2019 - 12:13
di Gaetan
Buone notizie.
Re: [RISOLTO] Microsoft Office 2019
Pubblicato: 15 giugno 2020 - 11:38
di Mickael Lombard
Sto creando un pacchetto di Office 2019 utilizzando WAPT e ho riscontrato un problema. Vorrei includere i file di installazione nel pacchetto, ma sembra che ci sia un problema con il percorso di origine.
Come hai configurato questa impostazione?
GRAZIE!
Pubblicato: 15 giugno 2020 - 22:03
di Gaetan
ho basato il mio lavoro su questo tutorial, nel caso possa esserti utile:
http://reseaux85.fr/index.php?title=Dep ... oft_Office
