[Risolto] 1.8.2.7303 => EXEC genera /opt/wapt/bin/python: errore di formato Exec
Pubblicato: 18 novembre 2020 - 10:30
Dopo l'aggiornamento di ieri sera, il servizio wpatserver non si avvia più:
In /var/log/syslog
In /var/log/dpkg.log:
Come si può risolvere questo problema?
In /var/log/syslog
Nov 18 10:03:26 wobani systemd[2612]: waptserver.service: Failed to execute command: Exec format error
Nov 18 10:03:26 wobani systemd[2612]: waptserver.service: Failed at step EXEC spawning /opt/wapt/bin/python: Exec format error
Nov 18 10:03:26 wobani systemd[1]: waptserver.service: Main process exited, code=exited, status=203/EXEC
Nov 18 10:03:26 wobani systemd[1]: waptserver.service: Failed with result 'exit-code'.Codice: Seleziona tutto
2020-11-18 04:09:20 upgrade tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:09:20 status half-configured tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status unpacked tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status half-installed tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status triggers-pending rsyslog:amd64 8.1901.0-1
2020-11-18 04:09:23 status unpacked tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:09:23 upgrade tis-waptsetup:all 1.8.2.7269 1.8.2.7303
2020-11-18 04:09:23 status half-configured tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status unpacked tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status half-installed tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status unpacked tis-waptsetup:all 1.8.2.7303
2020-11-18 04:09:23 startup packages configure
2020-11-18 04:09:23 configure tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf <none>
2020-11-18 04:09:23 status half-configured tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:10:54 status installed tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:10:54 configure libldap-common:all 2.4.47+dfsg-3+deb10u4 <none>
2020-11-18 04:10:54 status unpacked libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 status half-configured libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 status installed libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 configure tis-waptsetup:all 1.8.2.7303 <none>
2020-11-18 04:10:54 status unpacked tis-waptsetup:all 1.8.2.7303
2020-11-18 04:10:54 status half-configured tis-waptsetup:all 1.8.2.7303
2020-11-18 04:10:54 status installed tis-waptsetup:all 1.8.2.7303
