Non funziona ancora.
Tuttavia, il messaggio di errore è cambiato.
Ecco l'errore che si verifica quando si tenta di aggiornare un pacchetto dalla console (funzione: update-package).
Ho un problema con le impostazioni ma non riesco a capire dove, anche se tutto funzionava perfettamente prima della migrazione del server dal server della community.
________________________________________________________________________________________________
Downloading/Updating package content from upstream binary sources
URL used is: https://www.7-zip.org/download.html
CRITICAL:waptcore:Fatal error in update_package function: None : None:
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\connection.py", line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "socket.py", line 918, in getaddrinfo
socket.gaierror: [Errno 11002] getaddrinfo failed
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 353, in connect
conn = self._new_conn()
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x0A21D928>: Failed to establish a new connection: [Errno 11002] getaddrinfo failed
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 439, in send
resp = conn.urlopen(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 573, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.7-zip.org', port=443): Max retries exceeded with url: /download.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0A21D928>: Failed to establish a new connecti
on: [Errno 11002] getaddrinfo failed'))
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2928, in call_setup_hook
hookdata = hook_func()
File "C:\Users\AB3028~1\AppData\Local\Temp\wapt-20210723-11124700000.tmp\asb-7zip_x64-wapt\setup.py", line 50, in update_package
version = bs_find_all(url, 'b', proxies=proxies)[1].text.split('Zip ')[-1].split(' (')[0]
File "C:\Users\AB3028~1\AppData\Local\Temp\wapt-20210723-11124700000.tmp\asb-7zip_x64-wapt\setup.py", line 119, in bs_find_all
page = requests.get(url, proxies=proxies, headers=headers, **kwargs).text
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.7-zip.org', port=443): Max retries exceeded with url: /download.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0A21D928>: Failed to establish a new conne
ction: [Errno 11002] getaddrinfo failed'))
conn.connect()
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2932, in call_setup_hook
raise e
