[RISOLTO] Errore con il pacchetto Office 2016
Pubblicato: 24 gennaio 2023 - 11:54
Buongiorno
Sto provando a utilizzare il pacchetto per Office 2016, ma si blocca ogni volta e non capisco perché.
Ecco la console:
Avete qualche idea?
Sinceramente,
Tom
Ecco la console:
2023-01-24 11:53:50,502 CRITICAL Error importing c:\waptdev\ln-msoffice_2016-42_windows_PROD\setup.py :
File "C:\Program Files (x86)\wapt\waptutils.py", line 1520, in import_setup
File "imp.py", line 171, in load_source
File "<frozen importlib._bootstrap>", line 702, in _load
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 839, in exec_module
File "<frozen importlib._bootstrap_external>", line 976, in get_code
File "<frozen importlib._bootstrap_external>", line 906, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "c:\waptdev\ln-msoffice_2016-42_windows_PROD\setup.py", line 54
silentxml = ur"""<Configuration Product="ProPlus">
<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" />
<Setting Id="SETUP_REBOOT" Value="NEVER" />
</Configuration>
SyntaxError: invalid syntax
FATAL ERROR : SyntaxError: invalid syntax (setup.py, line 54)Sinceramente,
Tom
