[RISOLTO] Pacchetto tis-microsoft-teams-uwp
Pubblicato: 27 febbraio 2024 - 16:55
Volevo testare l'ultimo pacchetto Teams "UWP", ma si blocca durante l'installazione tramite un comando PowerShell:
Installing: MSTeams-x64.msix (23335.232.2637.4844)
File "C:\wapt\setuphelpers_windows.py", line 1194, in run_powershell
result = run(cmd,
File "C:\wapt\waptutils.py", line 2174, in run
raise CalledProcessErrorOutput(proc.returncode, cmd, ''.join(output+return_stderr))
waptutils.CalledProcessErrorOutput: Command 'powershell -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "QQBkAGQALQBBAHAAcAB4AFAAcgBvAHYAaQBzAGkAbwBuAGUAZABQAGEAYwBrAGEAZwBlACAALQBPAG4AbABpAG4AZQAgAC0AUABhAGMAawBhAGcAZQBQAGEAdABoACAAIgBNAFMAVABlAGEAbQBzAC0AeAA2ADQALgBtAHMAaQB4ACIAIAAtAFMAawBpAHAATABpAGMAZQBuAHMAZQA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : Élément introuvable._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error"> + CategoryInfo : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error"> + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
File "C:\wapt\common.py", line 4234, in install_wapt
File "C:\WINDOWS\TEMP\waptz0_us848\setup.py", line 22, in install
File "C:\wapt\setuphelpers_windows.py", line 1198, in run_powershell
raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
