[RISOLTO] Condivisione dei pacchetti Webots
Pubblicato: 14 aprile 2025 - 17:05
Condivido il mio pacchetto per il software webots, per il quale ho spinto la configurazione software iniziale un po' oltre rispetto al pacchetto tis (lingua francese, nessuna telemetria e disattivazione dell'aggiornamento automatico)
try:
from waptenterprise.waptservice.enterprise import get_active_sessions, start_interactive_process
except:
from waptservice.enterprise import get_active_sessions, start_interactive_process
r"""
# Declaring local variables
bin_name= glob.glob("webot*.exe")[0]
def get_version(app_registry_dict):
return app_registry_dict["version"].replace("R", "").replace("b",".2").replace("a",".1")
# Uninstalling others versions
for uninstall in installed_softwares(name="Webots"):
print("Removing: %s" % (uninstall["name"]))
killalltasks(control.get_impacted_process_list())
run(uninstall_cmd(uninstall["key"]))
# Installing the software
install_exe_if_needed(
bin_name,
silentflags="/VERYSILENT /ALLUSERS",
key="Webots_is1",
min_version=control.get_software_version(),
get_version=get_version
# Installing Windows Firewall rules
print('Add Windows Firewall rules')
add_netfirewallrule(r"webots-bin", r"C:\program files\webots\msys64\mingw64\bin\webots-bin.exe", profile="Domain")
def session_setup():
version= "R" + control.get_software_version().replace(".2","b").replace(".1","a")
# Set french language
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'language','fr',type=REG_SZ)
# Disable UpdateOnStartup
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'checkWebotsUpdateOnStartup','false',type=REG_SZ)
# Disable telemetry
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'telemetry','false',type=REG_SZ)
def audit():
run_session_setup(control.package)
return "OK"
def run_session_setup(package_name):
for session_id in get_active_sessions():
start_interactive_process("wapt-get", "--hide session-setup %s -f" % package_name, session_id=session_id) # , minimize=True
print('Uninstalling Windows Firewall rules')
remove_netfirewallrule("webots-bin")
