[RISOLTO] Pacchetto per EdrawMax - Aggiornato 08/2025
Pubblicato: 7 agosto 2025 - 12:55
Ho condiviso un pacco per il software Wondershare EdrawMax ma il pacchetto di aggiornamento non funziona più perché hanno cambiato sito.
Ecco una nuova versione che funziona.
setup.py:
controllare:
setup.py:
from setupdevhelpers import *
from os import rename
appver = control.get_software_version()
appname = control.name
install_exe_if_needed(r'edrawmax_%s.exe' % appver, silentflags=r'/VERYSILENT /NORESTART /ACCEPTEULA', min_version=appver, name=appname)
remove_desktop_shortcut(appname)
def session_setup():
remove_user_desktop_shortcut(appname)
def update_package():
url = control.changelog
latest_version = None
for col in bs_find_all(url, "h2", "class", "mb-3"):
if "Windows" in col.text:
latest_version = col.text.split("Windows V")[1].split(" ")[0]
break
if not latest_version:
error(r'Error fetching latest version from website !')
# Installers for all versions are availables here: https://support.wondershare.com/how-tos/wondershare/product-download.html
# It seems all installers contains "full5371" in file name
latest_url = r'https://download.edrawsoft.com/cbs_down/edraw-max_64bit_%s_full5371.exe' % latest_version
print(r'Latest version : %s' % latest_version)
print(r'Latest url : %s' % latest_url)
if Version(latest_version, 3) > Version(appver, 3):
installer = r'edrawmax_latest.exe'
installer_version = r'edrawmax_%s.exe'
wget(latest_url, installer)
# Get full version from binary
bin_version = get_version_from_binary(installer)
if Version(bin_version, 3) != Version(latest_version, 3):
error(r'Error : binary version and website version are not the same !')
# Renaming installer with full version
os.rename(installer, installer_version % bin_version)
control.version = '%s-%s'%(bin_version, control.version.split('-')[-1])
print('Changing version to: %s in WAPT\\control' % control.version)
remove_outdated_binaries(bin_version)
print("Already up to date")
package : xxx-edraw_max
version : 14.5.4.1333-104
architecture : x64
section : base
priority : optional
categories : Utilities
maintainer : XXXX
description : Edraw Max est un logiciel de diagramme d'affaires et technique en 2D qui aide à créer des diagrammes de flux, des organigrammes, des cartes mentales, des diagrammes de réseau, des plans d'étage, des diagrammes de flux de travail, des graphiques d'affaires et des diagrammes d'ingénierie.
depends :
conflicts :
maturity : PROD
locale : all
target_os : windows
min_wapt_version :
sources : https://www.edrawsoft.com/download-edrawmax.html
installed_size :
impacted_process : EdrawMax,EdrawMaxTray
description_fr :
description_pl :
description_de :
description_es :
description_pt :
description_it :
description_nl :
description_ru :
audit_schedule :
editor : EdrawSoft Co.,Ltd.
keywords :
licence : proprietary_restricted
homepage : https://edrawmax.wondershare.com/
valid_from :
valid_until :
forced_install_on :
changelog : https://edrawmax.wondershare.com/whats-new.html
min_os_version :
max_os_version :
