barra rovesciata nell'esecuzione del comando
Pubblicato: 13 settembre 2016 - 12:27
Sto provando a eseguire un comando nel file pyton.py, ma ogni volta le barre rovesciate vengono raddoppiate e il comando fallisce.
Il problema persiste, c:\ viene interpretato come c:\\.
Il comando da eseguire è:
O
Tutti questi comandi mi restituiscono quanto segue:
Come posso mantenere intatto il carattere "c:\" nel comando run?
GRAZIE.
powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\
run(r'powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\')
run(r'"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\"')
commandsm=r"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\"
run(commandsm)
2016-09-13 11:58:29,858 CRITICAL Fatal error in install script: CalledProcessError: Command '('"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\\ -verbose"',)' returned non-zero exit status 1:Traceback (most recent call last):
File "C:\wapt\common.py", line 3166, in install_wapt
File "c:\users\adminv~1\appdata\local\temp\waptxfvtxf\setup.py", line 71, in install
run(r'"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\ -verbose"')
File "C:\wapt\common.py", line 3013, in run
return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
File "C:\wapt\setuphelpers.py", line 602, in run
raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-09-13 11:58:29,940 CRITICAL Package chal-config-pc not installed due to errors : CalledProcessError: Command '('"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\\ -verbose"',)' returned non-zero exit status 1
GRAZIE.
