Hi folks,
Is there any idea of wapt having a wapt console via webgui?
It would be amazing!
[RESOLVED] wapt console via webGui
For what use do you need a web console?
Centralized management!
Today, wapt can be launched from multiple console at the same time.
Each administrator can launch the console from his station.
Yes, we have already done so, but since we use linux, we need to have a VM for this. Not that a VM is the problem, but if it had a webgui, it would be more organized and better to manage.sfonteneau a écrit : ↑22 mars 2018 - 14:49 Today, wapt can be launched from multiple console at the same time.
wapt works fine under winehq :
https://www.winehq.org/
During installation, you must uncheck the installation of the service.
Okay. I installed via playonlinux. Works!sfonteneau a écrit : ↑22 mars 2018 - 18:00 wapt works fine under winehq :
Thanks Vincent!!!Vincent CARDON a écrit : ↑22 mars 2018 - 23:32 Happiness for all admins, that's the goal of WAPT
Happiness for you first, then you can tell you friends.
Vincent
