[RESOLVED] run remote commands
Publié : 22 mars 2018 - 13:24
par empbilly
I searched and did not find a specific command to remotely run a command.
Is there anything for that?
I tried the following way. I need to run remotely, for example, the command "wapt-get generete-uuid".
I tried as follows, but gave error.
print('executing remote command')
run(r'c:\windows\system32\cmd.exe /c wapt-get generete-uuid')
Re: run remote commands
Publié : 22 mars 2018 - 14:01
Publié : 22 mars 2018 - 14:16
par empbilly
wow!! Thanks sfonteneau!!! Works like a charm!!
Publié : 23 mars 2018 - 21:27
par empbilly
sfonteneau,
Regarding my example,
This would work via WAPT?
Publié : 24 mars 2018 - 00:26
par htouvet
Theoritically,
would be enough as the run command starts a sub shell (cmd) by default.
generate-uuid could eventually work but a lot of other "wapt-get" would not work properly because only one wapt process must be running at a time (and the waptservice is a wapt process).
And if you can do what you need directly using python, you have more control to handle the exceptions (try: except: try finally: etc..) as you would have with a cmd shell
Publié : 26 mars 2018 - 14:41
par empbilly
htouvet a écrit : ↑24 mars 2018 - 00:26
Theoritically,
hello htouvet,
Using python directly does it need the target machine to have python installed or wapt client take care of it? Need execution with administrative rights?
Publié : 26 mars 2018 - 19:35
par dcardon
Hi empbilly,
empbilly a écrit : ↑26 mars 2018 - 14:41
wapt come with its own python 2.7 interpreter. It is located in the base directory of the wapt installation, normally c:\program files (x86)\wapt\waptpython.exe . You can add your own python interpreter if you really need it.
Cheers,
Publié : 26 mars 2018 - 21:30
par empbilly
The answer is in the topic of the link below.
viewtopic.php?f=10&t=1083
