Wapt1.5 & debian 9
Publié : 22 janv. 2018 - 17:29
Apres
/usr/bin/python /opt/wapt/waptserver/scripts/postconf.py
resultat
Quelqu'un a une idée
Apres
resultat
making a backup copy of the configuration file
Synchronizing state of postgresql.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable postgresql
psql: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
File "/opt/wapt/waptserver/scripts/postconf.py", line 523, in <module>
main()
File "/opt/wapt/waptserver/scripts/postconf.py", line 337, in main
ensure_postgresql_db()
File "/opt/wapt/waptserver/scripts/postconf.py", line 177, in ensure_postgresql_db
val = run(""" sudo -u postgres psql template1 -c " select usename from pg_catalog.pg_user where usename='wapt';" """, cwd='/opt/wapt')
File "/opt/wapt/waptserver/scripts/postconf.py", line 65, in run
return subprocess.check_output(*args, shell=True, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 219, in check_output
subprocess.CalledProcessError: Command ' sudo -u postgres psql template1 -c " select usename from pg_catalog.pg_user where usename='wapt';" ' returned non-zero exit status 2
