Bonjours á tous je suis nouveau dans le forum,
j' ai donc configurer mon serveur WAPT , pour distribuer l' OS via PXE
le service TFTP etant inclut, je n' ai pas eu besoin de la configurer
Lorsque je boot un PC via PXE, j'obtiens l'erreur suivant:
PXE-E3A: TFTP too many packages
Problem PXE-E3A: TFTP too many packages
Hi juniormateus,
First version of wapt, server, etc. (cf. forum rules above)
For wads, please add dhcp type and configuration (uefi, legacy, etc.)
Can you reproduce this error on another computer or on virtualbox?
There was a bug on the filesize attribute that has been fixed in the last version (there was an extra NULL character at the end of the filesize, most tftp client don't care, but some get buggy with that.
Could you please try with the bugfix release of today wapt-2.2.1.11932-6522dccb to see if you can reproduce this issue just to be sure that it isn't a bug related to weird filesize interpretation ?
Cheers,
Cheers,
thx for your quick answer i'll try update and let your know!
Hi , i've try to upgrade, but it look like i'm already on the last version!dcardon a écrit : ↑05 mai 2022 - 19:01 Hi juniormateus,
Cheers,
tis-waptserver is already the newest version (2.2.1.11932-6522dccb-debian-11-amd64).
tis-waptsetup is already the newest version (2.2.1.11932-6522dccb-debian-10-amd64).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
Yes i can download using tftpdcardon a écrit : ↑06 mai 2022 - 11:36 Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
We can try to deactivate the wapt tftp to see if with the official debian tftp it is better
in /etc/default/tftpd-hpa add :
and run :
systemctl stop wapttftpserver
apt-get install tftpd-hpa
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/var/www/wads/pxe
TFTP_ADDRESS="0.0.0.0:69"
TFTP_OPTIONS="--secure"
systemctl start tftpd-hpa
have you tried ?
