I think maybe because the machine, where i running the package are a windows server 2019, i will try on a windows 10 machinejuniormateus a écrit : ↑11 mai 2022 - 16:08I got this error, when try to duplicatejuniormateus a écrit : ↑11 mai 2022 - 16:01Thank You let me tested, and i will let you knowsfonteneau a écrit : ↑11 mai 2022 - 13:51 I just updated the tis-wads-requirement-minimal package
https://luti.tranquil.it/get_folder_res ... 93aW5kb3dz
it now includes the copy of the Bootsect.exe file if it is not present on your machine
you can duplicate the package from this repository : https://wapt.tranquil.it/wapt-testing/
http://snpy.in/3Qlvvk
Issue using WinPE Usb Key\Bootsect.exe
Yes try and get back to me
I don't see any 404 on a wads package on the store here
Apparently it's not our server returning a 404.
Hi i have one question, for better preparing the OS Boot via TFTP or Pen drive
Is it a requirement that the WAPT Console Management being installing on a Windows 10 machine ?
Can i use a windows 2019 server ? for Console Management ?
Because i receive another error on the windows 10
here is the print screen link: http://snpy.in/Fnn3d2
Everything should work fine also on a Windows 2019 server
Can you close the console
Delete folder %tmp%\winpe
And try again to create the winpe?
WARNING : the machine that generates winpe from the console must have the tis-wads-requirement-minimal package installed
I still receive this error, when try to download the new packagesfonteneau a écrit : ↑12 mai 2022 - 12:54 Everything should work fine also on a Windows 2019 server
link: http://snpy.in/6J9jjU
But the file is there...
https://wapt.tranquil.it/wapt-testing/t ... f7d66.wapt
You can download here and import as a file
Hi juniormateus
Thanks,
Please try to refrain to use url shortener on forum, one never now where it will take him...juniormateus a écrit : ↑12 mai 2022 - 15:44
Thanks,
