[RESOLU] Problem with the package tis-disable-telemetry
OlivierSchmitt
17 janv. 2025 - 14:46
Hello dear all,
https://wapt.tranquil.it/store/fr/detai ... _PROD.wapt
There seems to be a bug in this package.
Indeed, after installation the audits are ok.
At the next audit launched automatically, the audit status does not seem to return anything in the console tab "general".
When I look in Audit data tab, it is in Warning but without any message of indications.
When I do a force install, the audit status comes back as OK.
So I guess there is a bug?
21 janv. 2025 - 10:37
Indeed there was a wapt.install of the package itself in the audit function. I corrected the new package will be on the store soon.
OlivierSchmitt
30 janv. 2025 - 17:56
Many thanks for the futur update.
