Supprimer le fichier binaire "Install_PRNclient_FR_2021.0.2.10_win64.exe"
Pouvez-vous également tester sur un PC Windows 10 x64 ?
[RESOLU] Paquet Edt v2022 build 0.3.0 / Pronote v2022 build 0.3.0
olaplanche
Je vois donc je supprime le fichier .exe du waptdev et je update-package c ca?
Si oui j'ai ça comme erreur lors de l'update
Ligne de Commande : update-package-sources "c:\waptdev\gmwapt-client-pronote-2021-0210_0.2.10-1_x64_windows_PROD-wapt\WAPT\.."
Using config file: C:\Users\winadmin\AppData\Local\waptconsole\waptconsole.ini
Downloading/Updating package content from upstream binary sources
2022-06-09 13:33:16,528 CRITICAL Fatal error in update_package function: None : None:
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2974, in call_setup_hook
hookdata = hook_func()
File "c:\waptdev\gmwapt-client-pronote-2021-0210_0.2.10-1_x64_windows_PROD-wapt\setup.py", line 119, in update_package
page = wgets(control.sources,proxies=proxies)
File "C:\Program Files (x86)\wapt\waptutils.py", line 1130, in wgets
r = session.get(url, timeout=timeout, allow_redirects=True)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 528, in request
prep = self.prepare_request(req)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\sessions.py", line 456, in prepare_request
p.prepare(
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\models.py", line 316, in prepare
self.prepare_url(url, params)
File "C:\Program Files (x86)\wapt\Scripts\lib\site-packages\requests\models.py", line 390, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL '': No schema supplied. Perhaps you meant http://?
FATAL ERROR : None : None
Exit code: 3
>>> - Version de WAPT installée : 2.2.1.11949 Discovery
- OS du serveur : Linux / Debian 11
- OS de la machine d'administration/création des paquets : Windows 7
olaplanche
Arg j'ai oublié de mettre à jour l'url source sur le premier poste !
La bonne adresse est la suivante :
Pronote est vraiment compliquer à mettre en paquet.
J'ai toujours une série d'erreur en changeant la source
j'utilise ensuite le update-package (je n'ai pas le update-package sources)
et j'ai toujours cette série d'erreur
2022-06-09 13:44:43,438 CRITICAL Fatal error in update_package function: None : None:
p.prepare(
Exit code: 3
olaplanche
Ah mon avis y a un problème avec le pc de développement.
Pouvez-vous confirmer les points suivants :
- Le paquet tis-waptdev est bien installé sur le poste de développement ?
- Pyscripter est bien exécuter en tant qu'administrateur ?
Oui le waptdev est bien installé sur ma machine qui est la machine avec laquelle je gère la console wapt et le déploiement des paquets.
Et oui le pyscripter est bien exécuter en tant qu'administrateur.
Bonjour SebAranel,
Il y a des fonctionnalités qui ne sont que en version Entreprise, donc pour éviter d'induire les gens en erreurs par rapport à leur réponse, il est préférable de préciser l'édition (cf. votre pieds de post).
C'est depuis la version 2.2 c'est le même binaire pour la version Discovery et la version Entreprise, c'est juste la présence d'une licence qui change le mode de fonctionnement. Dans votre cas nb licence = -1, donc pas de licence présente.SebAranel a écrit : ↑08 juin 2022 - 08:17 Excusez moi pour la réponse un peu longue. Je viens de vérifier et je suis apparemment sur une version discovery de wapt en 2.2.1.11949, et pour la version de pyscripter je suis en version 3.6 je vous mets un screenshot.
Je ne sais pas si ça change quelque chose mais ma console m'indique discovery.
Oui effectivement je devais le modifier mais je n'en ai pas eu l'occasion.
Concernant les fonctionnalité on est d'accord que cela ne concerne que l'utilisation de la console et non le déploiement des paquets sur les postes?
Cordialement
SebAranel
Cordialement
SebAranel
