[RESOLU] pb maj 1.5.1.23 vers 1.6
cdeze
26 sept. 2018 - 14:19
j'obtiens ce message d'erreur
pouvez vous me dire si cela vous parle ?
merci
root@wapt:~# apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stable InRelease
Ign:3 http://cdn-fastly.deb.debian.org/debian stable-update InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stable Release
Ign:5 https://wapt.tranquil.it/debian/wapt-1.6 stretch InRelease
Ign:6 http://cdn-fastly.deb.debian.org/debian stable-update Release
Ign:7 http://deb.debian.org/debian stable-update/main all Packages
Ign:7 http://cdn-fastly.deb.debian.org/debian stable-update/main all Packages
Ign:9 http://deb.debian.org/debian stable-update/main amd64 Packages
Ign:9 http://cdn-fastly.deb.debian.org/debian stable-update/main amd64 Packages
Ign:10 http://deb.debian.org/debian stable-update/main Translation-en
Ign:10 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en
Ign:11 http://deb.debian.org/debian stable-update/main Translation-fr
Ign:11 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-fr
Ign:12 https://wapt.tranquil.it/debian/wapt-1.6 stretch Release
Ign:13 http://deb.debian.org/debian stable-update/main Translation-en_US
Ign:13 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en_US
Ign:14 http://deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:14 http://cdn-fastly.deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:15 http://deb.debian.org/debian stable-update/contrib all Packages
Ign:15 http://cdn-fastly.deb.debian.org/debian stable-update/contrib all Packages
Ign:16 http://deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:16 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:17 http://deb.debian.org/debian stable-update/contrib Translation-en
Ign:17 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en
Ign:18 http://deb.debian.org/debian stable-update/contrib Translation-fr
Ign:18 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-fr
Ign:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
Ign:20 http://deb.debian.org/debian stable-update/non-free all Packages
Ign:20 http://cdn-fastly.deb.debian.org/debian stable-update/non-free all Packages
Ign:21 http://deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:21 http://cdn-fastly.deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:22 http://deb.debian.org/debian stable-update/non-free Translation-fr
Ign:22 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-fr
Ign:23 http://deb.debian.org/debian stable-update/non-free Translation-en
Ign:23 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en
Ign:24 http://deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:24 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:25 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main all Packages
Ign:26 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en
Ign:27 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en_US
Ign:28 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-fr
Err:9 http://deb.debian.org/debian stable-update/main amd64 Packages
  404  Not Found
Err:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
  gnutls_handshake() failed: Error in the pull function.
Reading package lists... Done
W: The repository 'http://deb.debian.org/debian stable-update Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.6 stretch Release' does not have a Release file.
E: Failed to fetch http://deb.debian.org/debian/dists/stable-update/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch https://wapt.tranquil.it/debian/wapt-1.6/dists/stretch/main/binary-amd64/Packages  gnutls_handshake() failed: Error in the pull function.
E: Some index files failed to download. They have been ignored, or old ones used instead.
26 sept. 2018 - 15:13
Bonjour cdeze,
cdeze a écrit : ↑26 sept. 2018 - 14:19 j'obtiens ce message d'erreur
merci
Je pense que vous avez un problème avec votre téléchargement APT... Est ce que vous pourriez vérifier votre proxy? Est ce qu'il y a du MITM avec un certificat wildcard sur votre proxy?
cdeze
26 sept. 2018 - 16:03
bonjour
pas de MITM , mais bien un proxy qui ne doit pas connaitre un CIPHER ou une version de SSL
pour info
root@wapt:~# curl -vv https://wapt.tranquil.it/
*   Trying 100.78.56.201...
* TCP_NODELAY set
* Connected to (nil) (100.78.56.201) port 8001 (#0)
* Establish HTTP proxy tunnel to wapt.tranquil.it:443
> CONNECT wapt.tranquil.it:443 HTTP/1.1
> Host: wapt.tranquil.it:443
> User-Agent: curl/7.52.1
> Proxy-Connection: Keep-Alive
< HTTP/1.1 200 Connection established
* Proxy replied OK to CONNECT request
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to wapt.tranquil.it:443
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to wapt.tranquil.it:443
cdeze
26 sept. 2018 - 16:12
je pense que mon proxy n'autorise que le TLS 1.3 et que votre serveur n'a pas ce protocole
Me trompe je ?
26 sept. 2018 - 16:16
Bonjour Cdeze,
cdeze a écrit : ↑26 sept. 2018 - 16:12 je pense que mon proxy n'autorise que le TLS 1.3 et que votre serveur n'a pas ce protocole
Me trompe je ?
Je pense plutôt que votre proxy ne fait pas de TLS 1.2... Si votre proxy n'accepte que tu TLS 1.3, il ne va pas pouvoir se connecter à grand chose ! :-)
cdeze
26 sept. 2018 - 16:22
pourtant il en fait :
root@wapt:~# curl -vv https://forum.tranquil.it/
* TCP_NODELAY set
* Establish HTTP proxy tunnel to forum.tranquil.it:443
> CONNECT forum.tranquil.it:443 HTTP/1.1
> Host: forum.tranquil.it:443
* ALPN, offering h2
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
*  subject: OU=Domain Control Validated; OU=Gandi Standard Wildcard SSL; CN=*.tranquil.it
*  start date: May 25 00:00:00 2018 GMT
*  expire date: Jun  8 23:59:59 2020 GMT
*  subjectAltName: host "forum.tranquil.it" matched cert's "*.tranquil.it"
*  issuer: C=FR; ST=Paris; L=Paris; O=Gandi; CN=Gandi Standard SSL CA 2
*  SSL certificate verify ok.
26 sept. 2018 - 17:21
Bonjour cdeze,
cdeze a écrit : ↑26 sept. 2018 - 16:22 pourtant il en fait :
On passe aussi par un proxy, j'ai le même TLS et cipher dans les deux cas... J'avoue que je ne comprends pas...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://wapt.tranquil.it/
* Trying 192.168.149.13...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://forum.tranquil.it/
Simon me dit, dans le pire des cas, vous pouvez toujours récupérer les .deb avec votre navigateur et les installer avec un dpkg... :-)
cdeze
27 sept. 2018 - 08:46
le problème venait de notre filtrage chez bluecoat qui avait placé le site en suspect.
désolé
02 oct. 2018 - 20:04
Bonjour Cdeze,
cdeze a écrit : ↑27 sept. 2018 - 08:46 le problème venait de notre filtrage chez bluecoat qui avait placé le site en suspect.
désolé
merci pour le retour, je mets le topic en [RESOLU]
