[RESOLU] bulk change packet section to restricted
nliaudat
06 févr. 2020 - 09:03
Hi,
Is it a way to change many packet to restricted instead of base without recreating it nor changing version ?
I've checked in the postgresql database, but not found.
Regards
Dernière modification par nliaudat le 07 févr. 2020 - 11:04, modifié 1 fois.
06 févr. 2020 - 17:21
Hi Nliaudat,
nliaudat a écrit : 06 févr. 2020 - 09:03 Is it a way to change many packet to restricted instead of base without recreating it nor changing version ?
Regards
On a management computer with the private key configured, you can script something that do a
wapt-get edit tis-mypackage
then modifying the control file and doing a
wapt-get build-upload c:\waptdev\tis-mypackage
by default the build-upload command does not increment version number (you need to add a -i flag to increment)
Cheers,
nliaudat
07 févr. 2020 - 10:17
Many thanks !
