[RESOLU] Installation Java
rflandrois
02 mars 2022 - 11:22
Bonjour à tous,
Suite à la migration de WAPT Community vers Entreprise 2.1 nous n'arrivons plus a déployer Java. Ci dessous le Log d'erreur:
Installing ccmep-java8(=10.0-0)
Installing: ccmep-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1965, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 649, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1192, in _run
Exception: Erreur lors de l'installation de ['ccmep-java8(=10.0-0)']: erreurs dans les paquets [[PackageRequest(package='ccmep-java8',version=(Version('10.0.0.0'), 0),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'windows'],min_os_version=Version('10.0.19044'),max_os_version=Version('10.0.19044')), PackageEntry('ccmep-java8','10.0-0' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5007, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4009, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3922, in install_wapt\n exitstatus = setup.install()\n File "C:\\windows\\TEMP\\waptjrz1lcaa\\setup.py", line 41, in install\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1847, in error\n raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
self._run()
Une idée parce que je seche sur le message " please import and deploy the package adapted to your organization"
03 mars 2022 - 16:30
Bonjour rflandrois,
il y a un an ou deux Oracle a changé le licensing sur Java8 sur les dernières mises à jour (gratuite pour test mais pas pour prod). Et donc pour éviter aux utilisateurs d'installer une version de Java Oracle qui nécessite une licence (et de déclencher les foudres des commerciaux Oracle) on a renommé les paquets Java:
* Si vous avez une licence Java Oracle, vous pouvez utiliser le paquet : tis-oracle-java8-jre-nonfree
* Si vous avez pas de licence, il faut passer sur la version libre Adoptium : tis-adoptium-openjdk8-jdk
mgrita
02 juin 2023 - 15:01
Je suis en train de prendre mes marques avec WAPT et ses paquets et j'avais une question sur l'environnement Java avec la version OpenJDK17 d'Eclipse Adoptium.
La récupération du paquet dans le store wapt et le déploiement sur un poste s'effectuent correctement mais aucunes applications(ganttproject 2.8, freeplane 1.7 , geotorture 3.14) n'arrivent à se lancer.
J'ai constamment l'erreur suivante.
java error.PNG (4.34 Kio) Consulté 4139 fois
J'ai pourtant bien défini le bon environnement comme vous pouvez le voir ci-dessous.
jdk problem.PNG (139.92 Kio) Consulté 4139 fois
En effectuant certaines recherches j'ai eu à comprendre que c'était plus un soucis de variables d'environnement dans le registre.
Je voudrais bien plus d'éclaircissement sur le sujet, j'ai peur de ne pas en avoir saisi les contours.
Dans l'attente d'une réponse,
Cordialement
jpele
05 juin 2023 - 10:28
Ces logiciels dépendent d'un environnement d'exécution Java8 et ne sont donc pas compatibles avec Java17.
Je vous invite à importer un des paquets cités par mon collègue précédemment :
* Si vous n'avez pas de licence, il faut passer sur la version libre Adoptium : tis-adoptium-openjdk8-jdk
Vous pouvez également importer ceux que retrouvez dans le code du paquet tis-java8 (https://store.wapt.fr/store/fr/tis-java8) ou même packager vous-même le Java Runtime Environment 8 (JRE) de votre choix.
Jimmy
