[RESOLU] Paquet de certificat en erreur
eliottiph
02 mai 2022 - 10:53
Je suis actuellement en train de tester WAPT Enterprise sur une licence de démo.
J'ai créer un groupe de paquets de certificat qui sont lié à mes utilisateurs, lorsque j'essaie de les déployer voici le log d'erreur que j'obtiens :
Installing cam-cert-adm-etiphaneau(=1.0-1)
Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n    print("Certificate %%s found" %% (crt_location))\n                                   ^\nSyntaxError: invalid syntax\n']]
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1880, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1229, in _run
Exception: Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n    print("Certificate %%s found" %% (crt_location))\n                                   ^\nSyntaxError: invalid syntax\n']]
    self._run()
WAPT2.2 ENTREPRISE, Serveur Linux Debian 10, machine d'administration Windows 10.
D'avance merci pour votre retour.
Dernière modification par eliottiph le 02 mai 2022 - 11:48, modifié 1 fois.
02 mai 2022 - 11:47
Une erreur s'est glisser dans la dernière version.
Sur votre machine vous pouvez patcher le fichier : C:\Program Files (x86)\wapt\templates\setup_package_template_cert.py.tmpl
Dans le fichier vous pouvez remplacer : les %% par des % (double %% par des simple %)
Merci pour votre retour je viens de corriger
Cordialement
eliottiph
02 mai 2022 - 12:15
Bonjour Monsieur Fonteneau,
Merci pour votre retour.
L'erreur persiste malgré la modification du fichier setup_package_template_cert.py.tmpl
Maintenant ma console crash et désactive le service WAPT de ma machine Win10 console qui est aussi ma machine ou je test les déploiements ,la machine passe en statut "DISCONNECTED", ce qui m'oblige à aller le réactiver à la main.
Log:
  File "C:\Program Files (x86)\wapt\common.py", line 3967, in install_wapt
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1539, in import_setup
  File "C:\WINDOWS\TEMP\waptubbf04_n\setup.py", line 24
SyntaxError: invalid syntax (setup.py, line 24)
02 mai 2022 - 13:48
Oui effectivement le patch permet de corriger le paquet lors de sa création
Vous pouvez donc supprimer l'ancien paquet de certificat de votre repo privé puis fait un oublie sur la machine où le paquet avait déjà été installer:
wapt-get forget packagename
Où clique droit sur le paquet erreur sur la machine depuis la console et "oublier"
Le erreur que vous décrivez en revanche semble étrange et ne sont pas lier au problème précédent
Simon Fonteneau
05 mai 2022 - 19:23
le template de paquet pour le paquet de certificat a été corrigé dans la dernière release bugfix d'aujoud'hui wapt-2.2.1.11932-6522dccb
