Problem PXE-E3A: TFTP too many packages
juniormateus
05 mai 2022 - 17:02
Bonjours á tous je suis nouveau dans le forum,
j' ai donc configurer mon serveur WAPT , pour distribuer l' OS via PXE
le service TFTP etant inclut, je n' ai pas eu besoin de la configurer
Lorsque je boot un PC via PXE, j'obtiens l'erreur suivant:
05 mai 2022 - 19:01
Hi juniormateus,
First version of wapt, server, etc. (cf. forum rules above)
For wads, please add dhcp type and configuration (uefi, legacy, etc.)
Can you reproduce this error on another computer or on virtualbox?
There was a bug on the filesize attribute that has been fixed in the last version (there was an extra NULL character at the end of the filesize, most tftp client don't care, but some get buggy with that.
Could you please try with the bugfix release of today wapt-2.2.1.11932-6522dccb to see if you can reproduce this issue just to be sure that it isn't a bug related to weird filesize interpretation ?
Cheers,
juniormateus
06 mai 2022 - 06:43
thx for your quick answer i'll try update and let your know!
juniormateus
06 mai 2022 - 07:01
dcardon a écrit : ↑05 mai 2022 - 19:01 Hi juniormateus,
Cheers,
Hi , i've try to upgrade, but it look like i'm already on the last version!
tis-waptserver is already the newest version (2.2.1.11932-6522dccb-debian-11-amd64).
tis-waptsetup is already the newest version (2.2.1.11932-6522dccb-debian-10-amd64).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
06 mai 2022 - 11:36
Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
juniormateus
10 mai 2022 - 10:53
dcardon a écrit : ↑06 mai 2022 - 11:36 Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
Yes i can download using tftp
11 mai 2022 - 09:35
We can try to deactivate the wapt tftp to see if with the official debian tftp it is better
systemctl stop wapttftpserver
apt-get install tftpd-hpa
in /etc/default/tftpd-hpa add :
  TFTP_USERNAME="tftp"
  TFTP_DIRECTORY="/var/www/wads/pxe
  TFTP_ADDRESS="0.0.0.0:69"
  TFTP_OPTIONS="--secure"
and run :
systemctl start tftpd-hpa
13 juin 2022 - 15:29
have you tried ?
