Impossible d'installer la version 2.4
Publié : 26 mai 2023 - 10:33
Pour commencer, voici ma configuration :
- Version de WAPT installée : 2.3
- OS du serveur : Debian GNU/Linux 11 (bullseye)
- OS de la machine d'administration/création des paquets : Windows 11
Étant en train de tester WAPT, je voulais télécharger la dernière version mais c'est impossible. J'ai donc dû installer la 2.3 qui est fonctionnelle
De plus quand je vais sur l'URL "https://wapt.tranquil.it/Debian/wapt-2.4", j'ai "404 not found"  mais sur l'URL "https://wapt.tranquil.it/debian/wapt-2.3/" j'ai bien une arborescence.
root@TEST:~$ apt install apt-transport-https lsb-release gnupg wget -y
wget -O - https://wapt.tranquil.it/$(lsb_release -is)/tiswapt-pub.gpg | apt-key add -
echo "deb https://wapt.tranquil.it/$(lsb_release -is)/wapt-2.4/ $(lsb_release -c -s) main" > /etc/apt/sources.list.d/wapt.list
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
apt-transport-https is already the newest version (2.2.4).
gnupg is already the newest version (2.2.27-2+deb11u2).
lsb-release is already the newest version (11.1.0).
wget is already the newest version (1.21-1+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
--2023-05-26 10:27:12--  https://wapt.tranquil.it/Debian/tiswapt-pub.gpg
Resolving wapt.tranquil.it (wapt.tranquil.it)... 195.154.18.13, 2001:bc8:392f:101::13
Connecting to wapt.tranquil.it (wapt.tranquil.it)|195.154.18.13|:443... Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
connected.
HTTP request sent, awaiting response... 200 OK
Length: 3839 (3.7K) [application/octet-stream]
Saving to: ‘STDOUT’
-                                       100%[===============================================================================>]   3.75K  --.-KB/s    in 0s
2023-05-26 10:27:12 (446 MB/s) - written to stdout [3839/3839]
OK
root@TEST:~$ export DEBIAN_FRONTEND=noninteractive
apt update
apt install tis-waptserver tis-waptsetup -y
unset DEBIAN_FRONTEND
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Ign:4 https://wapt.tranquil.it/Debian/wapt-2.4 bullseye InRelease
Err:5 https://wapt.tranquil.it/Debian/wapt-2.4 bullseye Release
  404  Not Found [IP: 195.154.18.13 443]
E: The repository 'https://wapt.tranquil.it/Debian/wapt-2.4 bullseye Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
tis-waptserver is already the newest version (2.3.0.13516-69968974-debian-11-amd64).
tis-waptsetup is already the newest version (2.3.0.13516-69968974-debian-10-amd64).
root@TEST:~$
