WUA ''ValueError: time data '' does not match format '%m/%d/%Y''
Posté : 27 mars 2024 - 08:58
par tux
Sur certains postes Windows 10 et Windows server, j'ai des erreurs avec WUA.
Dernier statut d'erreur : ValueError: time data '' does not match format '%m/%d/%Y'
Est-ce que ce problème est corrigé dans la dernière version de WAPT?
Logs de la tache Install Windows Update :
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"12h",
 "install_scheduling":"6h",
 "install_delay":"",
 "postboot_delay":"10m"
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Bypassing scan, no change since last successful scan
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
Updates scan done.
re-enabling wuauserv previous state: 0
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 931, in update_local_status_as_dict
    install_date = str(datetime.datetime.strptime(kbw['InstalledOn'], '%d/%m/%Y'))
  File "_strptime.py", line 568, in _strptime_datetime
  File "_strptime.py", line 349, in _strptime
ValueError: time data '' does not match format '%d/%m/%Y'
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1934, in run
    self.running_task.run()
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 288, in _run
    self.result = wua.install_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1640, in install_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1260, in scan_updates_status
    dict_update_status[self.update_local_status_as_dict(u, _update_history,wmi_installed_windows_updates_result=wmi_installed_windows_updates_result)['update_id']] = self.update_local_status_as_dict(u, _update_history,wmi_installed_windows_updates_result=wmi_installed_windows_updates_result)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 933, in update_local_status_as_dict
    install_date = str(datetime.datetime.strptime(kbw['InstalledOn'], '%m/%d/%Y'))
    self._run()
Re: WUA ''ValueError: time data '' does not match format '%m/%d/%Y''
Posté : 28 mars 2024 - 19:25
par dcardon
Bonjour Sébastien,
oups, je crois qu'il y a bien un bug ici. Il semblerait que ni windows update, ni wmi n'a d'info sur la date d'installation. Cela doit pouvoir arriver si vous avez supprimer le dossier c:\windows\softwaredistribution\ et qu'il y a un autre bug en même temps que l'on a encore rencontré.
On regarde ça demain au bureau.
Posté : 12 avr. 2024 - 11:40
par tux
Pour information le dossier c:\windows\softwaredistribution\ est bien présent sur les postes en questions.
Avez vous identifier un workaround pour ce problème?
