[RESOLU] Erreur paquet Webview
Publié : 25 nov. 2024 - 16:51
par jcdemarque
Désolé, nous avons une nouvelle erreur avec le paquet Edge Webview qui est un prérequis pour notre client Citrix et le Teams PWA :
Erreur lors de l'installation de ['rh-webview2(=131.0.2903.51-10)']: erreurs dans les paquets [[PackageRequest(package='rh-webview2',version=(Version('131.0.2903.51'), 10),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22631'),max_os_version=Version('10.0.22631')), PackageEntry('rh-webview2','131.0.2903.51-10' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5437, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4390, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4296, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapth_eso_h4\\setup.py", line 15, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3957, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2214, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'MicrosoftEdgeWebView2RuntimeInstallerX64.exe/silent /install\' returned non-zero exit status 2147748109.\nOutput:\n']]
File "<string>", line 1681, in run
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 872, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1476, in _run
Exception: Erreur lors de l'installation de ['rh-webview2(=131.0.2903.51-10)']: erreurs dans les paquets [[PackageRequest(package='rh-webview2',version=(Version('131.0.2903.51'), 10),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22631'),max_os_version=Version('10.0.22631')), PackageEntry('rh-webview2','131.0.2903.51-10' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5437, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4390, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4296, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapth_eso_h4\\setup.py", line 15, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3957, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2214, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'MicrosoftEdgeWebView2RuntimeInstallerX64.exe/silent /install\' returned non-zero exit status 2147748109.\nOutput:\n']]
self._run()
Re: Erreur paquet Webview
Publié : 26 nov. 2024 - 08:47
par jlepiquet
Bonjour Jean-Charles,
Un nouveau paquet sera disponible en début d'après midi pour corriger ce problème.
Microsoft a modifié sa manière d'installer, nous avons corriger le paquet
Joeffrey
Publié : 26 nov. 2024 - 14:06
par jcdemarque
Merci cela résout le problème!
