[RESOLU] Erreur audit WAPT suite maj vers -38
PaulSLA
29 nov. 2024 - 09:31
Suite à la maj du paquets d'audit bitlocker, j'obtiens une erreur sans toucher au code à l'intérieur ( j'avais modifié pour ajouter notre certificat dans un 1er temps et ait ressayer sans modifier ). Dans les cas j'obtient cette erreur :
 https://srv-wapt.XXXX.dom/wapt/XXXX-audit-bitlocker_10.6.0-41_windows_10.0_PREPROD_f0fbc8a41032a3c9a76b1ee74e56ccfb.wapt : 9384 / 9384 (100%) (594 KB/s)
Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n    certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n    ^\nIndentationError: expected an indented block\n']]
    self._run()
Exception: Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n    certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n    ^\nIndentationError: expected an indented block\n']]
    self._run()
Est-ce que cela est normal / lié à un nouveau paramètre à configurer comme son certificat ou pas ?
jlepiquet
29 nov. 2024 - 10:01
C'est lié à un changement réalisé hier soir mal indenté.
On vient de revert le commit d'hier et repush le paquet en -39
Ca devrait être disponible dans la matinée.
Désolé pour le désagrément.
Joffrey
jlepiquet
29 nov. 2024 - 12:30
Le paquet est disponible sur le store https://wapt.tranquil.it/store/fr/wapt/ ... _PROD.wapt
