[RESOLU] Partage paquet webots
olaplanche
14 avr. 2025 - 17:05
Je vous partage mon paquet pour le logiciel webots pour lequel j'ai poussé un peu plus loin la conf initiale du logiciel que le paquet tis (langue fr, no telemetry et disable auto update) ;)
try:
    from waptenterprise.waptservice.enterprise import get_active_sessions, start_interactive_process
except:
    from waptservice.enterprise import get_active_sessions, start_interactive_process
r"""
    # Declaring local variables
    bin_name= glob.glob("webot*.exe")[0]
    def get_version(app_registry_dict):
        return app_registry_dict["version"].replace("R", "").replace("b",".2").replace("a",".1")
    # Uninstalling others versions
    for uninstall in installed_softwares(name="Webots"):
        print("Removing: %s" % (uninstall["name"]))
        killalltasks(control.get_impacted_process_list())
        run(uninstall_cmd(uninstall["key"]))
    # Installing the software
    install_exe_if_needed(
        bin_name,
        silentflags="/VERYSILENT /ALLUSERS",
        key="Webots_is1",
        min_version=control.get_software_version(),
        get_version=get_version
    # Installing Windows Firewall rules
    print('Add Windows Firewall rules')
    add_netfirewallrule(r"webots-bin", r"C:\program files\webots\msys64\mingw64\bin\webots-bin.exe", profile="Domain")
def session_setup():
    version= "R" + control.get_software_version().replace(".2","b").replace(".1","a")
    # Set french language
    registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'language','fr',type=REG_SZ)
    # Disable UpdateOnStartup
    registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'checkWebotsUpdateOnStartup','false',type=REG_SZ)
    # Disable telemetry
    registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'telemetry','false',type=REG_SZ)
def audit():
    run_session_setup(control.package)
    return "OK"
def run_session_setup(package_name):
    for session_id in get_active_sessions():
        start_interactive_process("wapt-get", "--hide session-setup %s -f" % package_name, session_id=session_id)  # , minimize=True
    print('Uninstalling Windows Firewall rules')
    remove_netfirewallrule("webots-bin")
17 avr. 2025 - 15:34
Bonjour Olivier,
Ingrid s'est occupé du paquet, il est dans wapt-testing [1], il devrait arriver bientôt sur le store. Merci pour le partage :-)
Je passe le topic en résolu.
[1] https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
