J'ai fait un paquet pour le client desktop ChatGPT pour MacOS, avec update_package() fonctionnel.
Note : d'après leur site, le DMG est compatible avec les processeur ARM uniquement.
Pour Windows, l'application est sur le store, donc il suffit d'utiliser le paquet template dédié à ça : https://wapt.tranquil.it/store/fr/tis-t ... -store-app
setup.py :
from setupdevhelpers import *
import plistlib
    # Initializing variables
    package_version = control.version.split("-")[0]
    app_name = control.name
    # Installing the package
    bin_name= glob.glob('%s*.dmg' % app_name)[0]
    install_dmg(bin_name, key="/Applications/%s.app" % app_name, min_version=package_version)
def update_package():
    bin_name = r'%s.dmg' % app_name
    dl_url = r'%s/%s' % (control.sources, bin_name)
    plist_file_name = r'Info.plist'
    # Downloading and extracting to compare version
    if isfile(bin_name):
        remove_file(bin_name)
    wget(dl_url, bin_name)
    if isfile(plist_file_name):
        remove_file(plist_file_name)
    unzip_with_7zip(bin_name, target=basedir, filenames=["%s Installer/%s.app/Contents/Info.plist" % (app_name, app_name)], extract_with_full_paths=False, recursive=False)
    plist_file = get_plist_obj(plist_file_name)
    latest_version = plist_file[r'CFBundleShortVersionString']
    print(r'Latest %s version is %s' % (app_name, latest_version))
    if Version(latest_version) > Version(control.get_software_version()):
        control.version = '%s-%s' % (latest_version, control.version.split('-', 1)[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        print(r'Already up to date !')
def get_plist_obj(plist_file):
    """ Returns a plist obj when given the path to a plist file. """
    with open(plist_file, 'rb') as fp :
        plist_obj = plistlib.load(fp)
    return plist_obj
package           : xxx-chatgpt
version           : 1.2025.231-2
architecture      : arm
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : ChatGPT Officiel Desktop Client
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : darwin
min_wapt_version  : 2.0
sources           : https://persistent.oaistatic.com/sidekick/public/
installed_size    :
impacted_process  : chatgpt
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : OpenAI
keywords          :
licence           : proprietary_free,wapt_public
homepage          : https://chatgpt.com
package_uuid      :
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://help.openai.com/en/articles/9703738-chatgpt-macos-app-release-notes
min_os_version    :
max_os_version    :
