Erreur postgresql jsquery dans les logs postgres
Mikael S
03 oct. 2025 - 08:11
Dans les logs de la bdd, je suis tombé sur ça
2025-10-02 23:59:27.817 CEST [1202] LOG:  starting PostgreSQL 15.14 (Debian 15.14-0+deb12u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv6 address "::1", port 5432
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv4 address "127.0.0.1", port 5432
2025-10-02 23:59:27.824 CEST [1202] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-10-02 23:59:27.856 CEST [1224] LOG:  database system was shut down at 2025-10-02 23:59:02 CEST
2025-10-02 23:59:27.888 CEST [1202] LOG:  database system is ready to accept connections
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt ERROR:  extension "jsquery" is not available
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt DETAIL:  Could not open extension control file "/usr/share/postgresql/15/extension/jsquery.control": No such file or directory.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt HINT:  The extension must first be installed on the system where PostgreSQL is running.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt STATEMENT:  CREATE EXTENSION if not exists jsquery;
2025-10-02 23:59:30.867 CEST [1794] wapt@wapt WARNING:  there is no transaction in progress
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt LOG:  could not send data to client: Broken pipe
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt STATEMENT:  COPY public.hostauditdata (id, host_id, value_id, value_date, value_section, value_key, value, expiration_date, created_on, created_by) TO stdout;
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt ERROR:  canceling statement due to user request
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt FATAL:  connection to client lost
Vous ne faites pas mention de la nécessité d'installer le paquet postgresql-15-jsquery sous bookworm dans le wiki. Ou alors sur une autre page que https://www.wapt.fr/en/doc/wapt-server- ... er-install
03 oct. 2025 - 11:04
Bonjour Mickael,
l'extension jsquery n'est plus nécessaire pour Wapt lui même. Et sur une fresh install le script de postconf ne l'install que si il est dispo sur le système. Mais c'est vrai que sur une restauration de sauvegarde ou une ré-install de serveur ça peut poser problème. Cette extension peut être utilisé dans les requêtes SQL json.
Je vais voir avec l'équipe on le remet dans la doc à l'install ou si l'on voit comment mieux nettoyer cela lors d'un upgrade.
Répondre
