[RESOLU] correction du paquet OBS studio
Publié : 27 avr. 2026 - 13:53
wapt entreprise 2.6.1.17705
serveur : debian 12
machine à paquet: win 11
Pourriez-vous corriger la fonction uninstall() présente dans le paquet OBS studio du store : https://wapt.tranquil.it/store/fr/detai ... _PROD.wapt
serveur : debian 12
impacted_third_party_processes = [
"msedge",
"msedgewebview2",
"Rocket.Chat",
"Teams",
"msteams",
"LogiTune",
"NVIDIA Broadcast",
bin_name = glob.glob("OBS-Studio-*.exe")[0]
try:
install_exe_if_needed(
bin_name,
silentflags="/S",
key="OBS Studio",
min_version=control.get_software_version(),
killbefore=impacted_third_party_processes if force else [],
except Exception as e:
if e.returncode == 6:
for p in impacted_third_party_processes:
if isrunning(p):
print(f"{p} is running")
error(
'Installation failed with "exit status 6"\nIt means that there is a program running that may be using OBS Virtual Camera\nYou can force install this package if you want to try killing them before'
remove_programs_menu_folder("OBS Studio")
