J'ai procédé à quelques nouveaux tests.
- Le paquet 2026 (sortie de preprod) téléchargé depuis wapt store ne fonctionne pas. Erreur suivante (toujours à la ligne 51 comme signalé précédemment) :
Installing: Install_EDTclient_FR_2026.2.5_win64.exe (2.5)
Erreur lors de l'installation de ['lfkl-edt-client(=2026.2.5-5)']: erreurs dans les paquets [[PackageRequest(package='lfkl-edt-client',version=(Version('2026.2.5.0'), 5),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('lfkl-edt-client','2026.2.5-5' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5723, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4629, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4534, in install_wapt\n exitstatus = setup.install()\n File "C:\\Program Files (x86)\\wapt\\private\\tmp\\waptm7jr4t9m\\setup.py", line 51, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4451, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1762, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2423, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"Install_EDTclient_FR_2026.2.5_win64.exe" -s -f1"C:\\\\Program Files (x86)\\\\wapt\\\\private\\\\tmp\\\\waptm7jr4t9m\\\\install_config.iss" -f2"C:\\\\Windows\\\\Temp\\\\Install_EDTclient_FR_2026.2.5_win64.log"\' returned non-zero exit status 2147753984.\nOutput:\n']]
File "<string>", line 1696, in run
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 891, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1525, in _run
Exception: Erreur lors de l'installation de ['lfkl-edt-client(=2026.2.5-5)']: erreurs dans les paquets [[PackageRequest(package='lfkl-edt-client',version=(Version('2026.2.5.0'), 5),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('lfkl-edt-client','2026.2.5-5' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5723, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4629, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4534, in install_wapt\n exitstatus = setup.install()\n File "C:\\Program Files (x86)\\wapt\\private\\tmp\\waptm7jr4t9m\\setup.py", line 51, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4451, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1762, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2423, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"Install_EDTclient_FR_2026.2.5_win64.exe" -s -f1"C:\\\\Program Files (x86)\\\\wapt\\\\private\\\\tmp\\\\waptm7jr4t9m\\\\install_config.iss" -f2"C:\\\\Windows\\\\Temp\\\\Install_EDTclient_FR_2026.2.5_win64.log"\' returned non-zero exit status 2147753984.\nOutput:\n']]
self._run()
Merci, cordialement.
