Sinon sur 1 salle de 6 PC sous XP, j’ai le message :
Installing dst-sketchup2016
EWaptSetupException: Fatal error : MSI SketchUp2016-x86.msi has been installed but the uninstall key
{CF062509-06B2-4F57-9373-166B04719F94} can not be found
Et sur les mêmes PC avec la version 2015 :
installing dst-sketchup2015
Exception: The uninstall key: {A1391613-0694-43DF-A4FC-144CC26BCDCB} has not been found in system registry after software installation.
Toujours dans la même salle, le PC prof (identique au mien, un dell 3020 en win7 64 bits) installe bien la version 2017 + vc2015 + dotnetfx4.5 mais rien ne se passe quand on clique dessus…
import platform
# registry key(s) where WAPT will find how to remove the application(s)
# command(s) to launch to remove the application(s)
uninstallstring = []
# list of required parameters names (string) which can be used during install
required_params = []
# if you want to modify the keys depending on environment (win32/win64... params..)
global uninstallkey
global uninstallstring
softname = 'Sketchup'
versionsoft = '16.1.1450'
check_installed_soft = installed_softwares(softname)
if check_installed_soft:
key=uninstall['key']
if installed_softwares(uninstallkey=key):
if Version(uninstall['version']) < Version(versionsoft):
run_notfatal(cmd)
if iswin64():
print('Installation de sketchup 2017')
install_msi_if_needed('SketchUp2017-x64.msi',killbefore=['SketchUp.exe'])
uninstallkey.append('{F124B571-EFA9-40F2-81B3-32AB0232429A}')
print('installing dst-sketchup2016')
install_msi_if_needed('SketchUp2016-x86.msi',killbefore=['SketchUp.exe'])
uninstallkey.append('{CF062509-06B2-4F57-9373-166B04719F94}')
