office 2016
Publié : 19 mai 2017 - 14:44
				i am having trouble creating office pro plus 2016 package. I have followed the instructions on reseaux85 :
- copy office CD to folder
- run setup.exe /admin within office folder
- create template "wapt-get make-template setup.exe"
- i replace contents of setup.py from newly created wapt-package folder
- i copy contents of office folder to root of wapt-package folder
- build and upload: " Wapt-get build-upload <wapt-package folder>"
when i add it to a host, it fails everytime with a not very helpful :
"error during install of <package>: errors in packages <package>"
can you provide some help? thank you
setup.py:
setup.py:
    def uninstall_office_modules():
        print('Suppression des anciens modules office..')
        check_installed_soft = installed_softwares('Microsoft Office System')
        if check_installed_soft:
                key=uninstall['key']
                if installed_softwares(uninstallkey=key):
                    run(cmd)
    def uninstall_office365():
        print('Suppression Office 365')
        check_installed_soft = installed_softwares('office 365')
                    run(cmd)
    def killsoft():
      for soft in ('WINWORD.EXE','POWERPNT.EXE','EXCEL.exe','MSPUB.EXE','MSACCESS.EXE','INFOPATH.EXE','lync.exe','ONENOTE.EXE','OUTLOOK.EXE','ONENOTEM.EXE','MSOSYNC.EXE','GROOVE.EXE'):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    softname = 'Microsoft Office Professionnel Plus 2016'
    check_installed_out = installed_softwares(softname)
    print('installing Office 2016')
    if not check_installed_out:
            cmd = '"setup.exe" /adminfile "silent.msp"'
            cmd = 'msiexec.exe /p silent.msp'
    killsoft()
        error('End audit did not find the software.')
    fichier = open("%s\silent.xml" % programfiles32, "w" )
    fichier.write('<Configuration Product="ProPlus"> \n')
    fichier.write('<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" /> \n')
    fichier.write('   <Setting Id="SETUP_REBOOT" Value="NEVER" /> \n')
    fichier.write('</Configuration> \n')
    fichier.close()
    run('"%s\Common Files\microsoft shared\OFFICE16\Office Setup Controller\Setup.exe" /uninstall ProPlus /config "%s\silent.xml"' % (programfiles32,programfiles32),timeout=1200)
    remove_file(r'%s\silent.xml'% programfiles32)
