Guten Morgen
Hier ist der Code für setup.py. Die drei Zeilen mit den Hochschulinformationen wurden entsprechend angepasst. Ich habe ihn nur zur Veranschaulichung geändert.
import platform
# Defining variables
bin_name_string = 'Install_PRNclient_FR_%s.%s_win64.exe'
app_uninstallkey = '{E20E5011-C887-40D8-8C26-99460A24F860}'
edition = 'v2021.0'
SERVERNAME = 'Adresse du serveur du college' # Le nom DNS du serveur pronote
SERVERPORT = 'Port du serveur' # Le port TCP du serveur pronote
NOMETAB = 'Nom du Collège' # Utilisé pour personnaliser le nom du raccourci sur le bureau
# Initializing variables
package_version = control.version.split('-',1)[0]
bin_name = bin_name_string % (edition[1:5],package_version)
print('Installing: %s' % bin_name)
import tempfile
import codecs
pathinstallfile = makepath(tempfile.gettempdir(),'Setup.iss')
if installed_softwares ('INDEX EDUCATION - Client PRONOTE 2020 - 64bit'):
data = r"""[InstallShield Silent]
Version=v7.00
File=Response File
[File Transfer]
OverwrittenReadOnly=NoToAll
[{E20E5011-C887-40D8-8C26-99460A24F860}-DlgOrder]
Dlg0={E20E5011-C887-40D8-8C26-99460A24F860}-SdLicense2Rtf-0
Count=6
Dlg1={E20E5011-C887-40D8-8C26-99460A24F860}-SdAskDestPath-0
Dlg2={E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-0
Dlg3={E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-1
Dlg4={E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-2
Dlg5={E20E5011-C887-40D8-8C26-99460A24F860}-SdFinish-0
[{E20E5011-C887-40D8-8C26-99460A24F860}-SdLicense2Rtf-0]
Result=1
[{E20E5011-C887-40D8-8C26-99460A24F860}-SdAskDestPath-0]
szDir=C:\Program Files\Index Education\Pronote 2021\Réseau\Client
Result=1
[{E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-0]
Result=1
Sel-0=0
[{E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-1]
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
[{E20E5011-C887-40D8-8C26-99460A24F860}-AskOptions-2]
Result=1
Sel-0=0
[{E20E5011-C887-40D8-8C26-99460A24F860}-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
Version=v7.00
File=Response File
[File Transfer]
Count=5
Dlg4={E20E5011-C887-40D8-8C26-99460A24F860}-SdFinish-0
Result=1
Result=1
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
Result=1
Sel-0=0
Result=1
bOpt1=0
bOpt2=0
fichier = codecs.open(pathinstallfile, "w", encoding='mbcs')
fichier.write(data)
fichier.close()
install_exe_if_needed(bin_name,silentflags='-s -f1%s' % pathinstallfile,key=app_uninstallkey,min_version=package_version,killbefore='Client PRONOTE.exe')
uninstallkey.remove(app_uninstallkey)
# Deleting response file
remove_file(pathinstallfile)
# Creating desktop shortcut for all users
create_desktop_shortcut(r'Pronote%s - %s' % (edition[1:5],NOMETAB),target=u'C:\Program Files\Index Education\Pronote %s\Réseau\Client\Client PRONOTE.exe' % edition[1:5],arguments=r'-Adresse "%s" -PortTcp "%s"' % (SERVERNAME,SERVERPORT))
def update_package():
print('Downloading/Updating package content from upstream binary sources')
proxies = get_proxies()
if not proxies:
app_name = control.name
url = control.sources
app_arch = control.architecture
if app_arch == 'x64':
dl_arch = 'win64'
dl_arch = 'win32'
# Getting latest version from official website
page = wgets(control.sources,proxies=proxies)
for line in page.splitlines() :
if ' CLIENT PRONOTE 2021' in line :
version = line.split('- ')[-1].split(' <')[0]
break
latest_bin = bin_name_string % (edition[1:5],version)
url_dl = 'https://tele3.index-education.com/telechargement/pn/%s/exe/Install_PRNclient_FR_%s.%s_%s.exe' % (edition,edition[1:5],version,dl_arch)
print("Latest %s version is: %s" % (app_name,version))
print("Download url is: %s" % url_dl)
# Downloading latest binaries
if not isfile(latest_bin):
print('Downloading: %s' % latest_bin)
wget(url_dl,latest_bin,proxies=proxies)
# Checking version from file
version_from_file = get_version_from_binary(latest_bin)
if version != version_from_file:
os.rename(latest_bin,bin_name_string % (edition[1:5],version_from_file))
version = version_from_file
control.version = '%s-%s'%(version,int(control.version.split('-')[-1])+1)
print('Changing version to: %s in WAPT\\control' % control.version)
# Deleting outdated binaries
def get_proxies():
if platform.python_version_tuple()[0] == '3':
from urllib.request import getproxies
from urllib import getproxies
return getproxies()
def get_version_from_binary(filename):
if filename.endswith('.msi'):
return get_msi_properties(filename)['ProductVersion']
return get_file_properties(filename)['ProductVersion']
def remove_outdated_binaries(version, list_extensions=['exe','msi','deb','rpm','dmg','pkg'], list_filename_contain=None):
if type(list_extensions) != list:
list_extensions = [list_extensions]
if list_filename_contain:
if type(list_filename_contain) != list:
list_filename_contain = [list_filename_contain]
list_extensions = ['.' + ext for ext in list_extensions if ext[0] != '.']
for file_ext in list_extensions:
for bin_in_dir in glob.glob('*%s' % file_ext):
if not version in bin_in_dir:
remove_file(bin_in_dir)
for filename_contain in list_filename_contain:
if not filename_contain in bin_in_dir:
def get_proxies_from_wapt_console():
proxies = {}
if platform.system() == 'Windows':
waptconsole_ini_path = makepath(user_local_appdata(), 'waptconsole', 'waptconsole.ini')
waptconsole_ini_path = makepath(user_home_directory(), '.config', 'waptconsole', 'waptconsole.ini')
if isfile(waptconsole_ini_path):
proxy_wapt = inifile_readstring(waptconsole_ini_path, 'global', 'http_proxy')
if proxy_wapt:
proxies = {'http': proxy_wapt, 'https': proxy_wapt}
return proxies
print('uninstalling: %s' % control.package)
import tempfile
pathuninstallfile = makepath(tempfile.gettempdir(),'Uninstall.iss')
Version=v7.00
File=Response File
[File Transfer]
Dlg0={E20E5011-C887-40D8-8C26-99460A24F860}-MessageBox-0
Count=2
Dlg1={E20E5011-C887-40D8-8C26-99460A24F860}-SdFinishReboot-0
[{E20E5011-C887-40D8-8C26-99460A24F860}-MessageBox-0]
Result=6
[{E20E5011-C887-40D8-8C26-99460A24F860}-SdFinishReboot-0]
Result=1
BootOption=0
fichier = open(pathuninstallfile, "w")
fichier.write(data)
fichier.close()
run(r'"%s\InstallShield Installation Information\%s\setup.exe" -s -uninst -f1%s' % (programfiles32,app_uninstallkey,pathuninstallfile))
remove_file(pathuninstallfile)
# Removing desktop shortcut for all users
remove_desktop_shortcut('Pronote%s - %s.lnk' % (edition[1:5],NOMETAB))
# Uninstalling Auto Update Agent
run('"MsiExec.exe" /X{775E087D-A428-428C-A5FD-000010008000} /qn')
Und das hier hat die Kontrolle
package : gmwapt-client-pronote-2021-0210
version : 0.2.10-1
architecture : x64
section : base
priority : optional
categories :
maintainer : winadmin
description : Client PRONOTE 2021 - 64bit (Index Education)
depends :
conflicts :
maturity : PROD
locale :
target_os : windows
min_wapt_version :
sources :
installed_size :
impacted_process :
description_fr :
description_pl :
description_de :
description_es :
description_pt :
description_it :
description_nl :
description_ru :
audit_schedule :
editor :
keywords :
licence :
homepage :
package_uuid : 692f5a90-88e4-4b2d-8cc0-3a5a7b35ed86
valid_from :
valid_until :
forced_install_on :
changelog :
min_os_version :
max_os_version :
icon_sha256sum :
signer : wapt
signer_fingerprint: 3d98c6bd75c8444596edecb80c04dda1ac217d841674700541eb14fde7ddaad6
signature : PB0R1D+WGx8L5CFEP4qp0P/Y9ypNZh5HVcV+HtFW1/f6a3Xu+K5X6Fwr62d33S2o2HdtsdOIuZT4n9w5lzz+6PgEA8rIF+aCpMIFoU/yRWQ2n71ecf7R9cehBRIBhCWBKpFgYNug0saL/Zk3Cag2b7ffuQibdHp4nKdmX6wilUpfbHXXtnskMTsvXAhaXZxCFe3yHjmPFML3URTEJX5/7LWKlAQ1u0W1PYx9vd8PH2nw6RaMjcQYgEgu4hZPscqm5RQqIq53jg+EutVPqNyBExKAJM2hOG0TJfNt6TFjxA/b/LnwJjBvHa1/GR0Vdm+fOTXKvhmmEsAwIrEYitbVNg==
signature_date : 2022-06-08T11:54:39.301511
signed_attributes : package,version,architecture,section,priority,name,categories,maintainer,description,depends,conflicts,maturity,locale,target_os,min_wapt_version,sources,installed_size,impacted_process,description_fr,description_pl,description_de,description_es,description_pt,description_it,description_nl,description_ru,audit_schedule,editor,keywords,licence,homepage,package_uuid,valid_from,valid_until,forced_install_on,changelog,min_os_version,max_os_version,icon_sha256sum,signer,signer_fingerprint,signature_date,signed_attributes
Ich habe es aus PyScripter abgerufen; ich hoffe, ich habe keinen Fehler gemacht und dass dies das ist, was Sie sehen wollten
Aufrichtig
SebAranel
