Windows Update-Scan fehlgeschlagen
t.heroult
Nachrichten: 309
Anmeldung: 8. Dezember 2020 - 10:13 Uhr
21. Februar 2023 – 15:55 Uhr
Guten Morgen
Auf einem Server erhalte ich nach einer Minute beim Ausführen des Update-Scans folgende Fehlermeldung:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"None",
 "install_scheduling":"None",
 "install_delay":"None",
 "postboot_delay":"10m"
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
re-enabling wuauserv previous state: 2
(-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 216, in _run
    self.result = wua.scan_updates_status(self.force)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 914, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 822, in updates
    search_job = self.update_searcher().BeginSearch(self.params.filter, scb_interface, None)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 784, in update_searcher
    self._update_service = self.update_service_manager().AddScanPackageService("Offline Sync Service", self.wsusscn2)
  File "C:\Windows\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateServiceManager2.py", line 36, in AddScanPackageService
    ret = self._oleobj_.InvokeTypes(1610743814, LCID, 1, (9, 0), ((8, 1), (8, 1), (3, 49)),serviceName
pywintypes.com_error: (-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
0x80020009 (Une exception s’est produite.): 0x80240031 ((unable to get meaning for error code 0x80240031))
    self._run()
Irgendwelche Ideen?
Aufrichtig,
Tom
Server: WAPT Enterprise 2.6.1.17786 auf Debian
Konsolen: Windows 10 & 11
Infrastruktur: Windows
Nachrichten: 438
21. Februar 2023 – 18:17 Uhr
Guten Abend,
Der Fehler würde bedeuten: „Eine oder mehrere Windows Update-Komponenten in der Registrierung sind möglicherweise beschädigt, fehlerhaft oder fehlen.“
die Bestellung
sfc /scannow
Das Ausführen des Befehls in einer Eingabeaufforderung mit Administratorrechten kann zur Lösung des Problems beitragen.
Ruhige IT
Nachrichten: 1982
24. Februar 2023 – 14:21 Uhr
Hallo Thomas,
hat die Ausführung von sfc /scannow das Problem auf dem Rechner behoben? (Dann können wir den Thread schließen.)
Denis Cardon – Tranquil IT
t.heroult
Nachrichten: 309
2. März 2023 – 14:29 Uhr
Ich kann es gerade nicht testen; der Server wartet auf den Neustart, und `sfc /scannow` wartet auf den Abschluss des Neustarts, bevor es ausgeführt wird.
Das kann eine Weile dauern…
