WUA-Fehler: Datei oder Verzeichnis nicht gefunden
t.heroult
Nachrichten: 309
Anmeldung: 8. Dezember 2020 - 10:13 Uhr
10. Oktober 2022 – 15:53 ​​Uhr
Guten Morgen
Seit einigen Tagen bemerke ich auf mehreren Windows 10-Systemen beim Scannen nach Windows-Updates folgenden Fehler:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download": false,
 "default_allow": false,
 "include_potentially_superseded_updates": false,
 "filter": "Type='Software' or Type='Driver'",
 "download_scheduling": "5d",
 "install_scheduling": "24h",
 "install_delay": "1d",
 "postboot_delay": "10m"
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Waiting for WUA search to complete
WUA Search completed !
Done searching
re-enabling wuauserv previous state: 2
[Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 233, in GetModuleForCLSID
    __import__(sub_mod_name)
ModuleNotFoundError: No module named 'win32com.gen_py.B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0.ISearchResult'
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 699, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 232, in _run
    self.result = wua.scan_updates_status(self.force)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 919, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 854, in updates
    search_result = self.update_searcher().EndSearch(search_job)
  File "C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateSearcher3.py", line 48, in EndSearch
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 96, in Dispatch
    return __WrapDispatch(dispatch, userName, resultCLSID, typeinfo, clsctx=clsctx)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 37, in __WrapDispatch
    klass = gencache.GetClassForCLSID(resultCLSID)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 180, in GetClassForCLSID
    mod = GetModuleForCLSID(clsid)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 241, in GetModuleForCLSID
    makepy.GenerateChildFromTypeLibSpec(sub_mod, info)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\makepy.py", line 319, in GenerateChildFromTypeLibSpec
    gen.generate_child(child, dir_path_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 1049, in generate_child
    self.file = self.open_writer(out_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 786, in open_writer
    return open(temp_filename, "wt", encoding=encoding)
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
2 : No such file or directory
    self._run()
Der Ordner C:\Windows\temp\gen_py\3.8 ist tatsächlich vorhanden...
Wenn ihr irgendwelche Ideen habt, bin ich ganz Ohr.
Aufrichtig,
Tom
Server: WAPT Enterprise 2.6.1.17786 auf Debian
Konsolen: Windows 10 & 11
Infrastruktur: Windows
Nachrichten: 1982
10. Oktober 2022 – 16:47 Uhr
Hallo Tom,
es ist schon eine Weile her, seit wir das letzte Mal etwas über gencache.py gehört haben… Dabei handelt es sich um dynamisch generierte Bindungen an Windows-COM-Objekte, insbesondere an das Windows-Update-Objekt. Das ist nicht gerade der eleganteste Aspekt von Python unter Windows.
Ich frage meine Kollegen, ob wir diese Bindungen während der Agenteninstallation/-aktualisierung vorab generieren können. Dadurch würde verhindert, dass sie im TEMP-Ordner erstellt werden. Ich denke, der Virenscanner ist wahrscheinlich von der Anwesenheit dieser Dateien überrascht.
Ich halte dich auf dem Laufenden. Könntest du in der Zwischenzeit bitte in der Konsole deines Virenscanners nachsehen, ob die betreffenden Dateien nicht versehentlich gelöscht wurden?
Viele Grüße,
Denis Cardon – Tranquil IT
t.heroult
Nachrichten: 309
11. Oktober 2022 - 09:28 Uhr
Hallo Denis
, okay, ich verstehe, welches Problem du hast. Das ist wirklich ärgerlich.
Ich habe gerade die Konsole (SentinelOne) überprüft und konnte keine Meldungen zu diesem Problem auf den betroffenen Rechnern finden.
Tut mir leid, aber es sieht so aus, als ob wir nicht weiterkommen. :(
Ich stehe dir aber gerne für ein paar Tests zur Verfügung, falls du möchtest.
Viele Grüße,
Tom
t.heroult
Nachrichten: 309
15. Mai 2023 - 11:28 Uhr
ich habe dieses Problem weiterhin regelmäßig.
Aktuell sind 5 Windows 10 Pro-Rechner betroffen.
Nachrichten: 2349
16. Mai 2023 – 15:08 Uhr
In solchen Fällen wird die Datei
ist auf dem Rechner vorhanden (ohne den wapt-Dienst neu zu starten)
t.heroult
Nachrichten: 309
22. Mai 2023 – 14:11 Uhr
Tatsächlich ist der Ordner vorhanden.
Wenn ich ihn lösche und einen Scan durchführe, wird er neu erstellt und der Fehler tritt erneut auf.
Nachrichten: 2349
22. Mai 2023 – 16:38 Uhr
und die Datei
C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\ISearchResult.py
Ist er anwesend?
t.heroult
Nachrichten: 309
23. Mai 2023 - 09:36 Uhr
Nein.
Ich habe nur zwei Dateien im Ordner 3.8:
- __init__.py
- dicts.dat
Nachrichten: 2349
23. Mai 2023 - 09:59 Uhr
Der Code, der die Datei generiert, lautet wie folgt:
C:\Windows\System32>waptpython
Python 3.8.16 (default, Mar  1 2023, 11:11:02) [MSC v.1929 32 bit (Intel)] on win32
>>> import win32com.client
>>> win32com.client.gencache.EnsureDispatch("Microsoft.Update.Session")
Könnten Sie versuchen, es in einem Windows-Terminal zu starten?
Am Ende sollten Sie normalerweise die folgende Datei haben:
type %tmp%\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\__init__.py
t.heroult
Nachrichten: 309
23. Mai 2023 – 14:09 Uhr
Super, es hat auf beiden Rechnern funktioniert.
Vielen Dank!
