[GELÖST] Paket tis-microsoft-teams-uwp
Gälen
Nachrichten: 254
Anmeldung: 22. November 2015 - 08:37 Uhr
27. Februar 2024 – 16:55 Uhr
Ich wollte das neueste Teams-Paket „UWP“ testen, aber es stürzt während der Installation bei einem PowerShell-Befehl ab:
Installing: MSTeams-x64.msix (23335.232.2637.4844)
  File "C:\wapt\setuphelpers_windows.py", line 1194, in run_powershell
    result = run(cmd,
  File "C:\wapt\waptutils.py", line 2174, in run
    raise CalledProcessErrorOutput(proc.returncode, cmd, ''.join(output+return_stderr))
waptutils.CalledProcessErrorOutput: Command 'powershell -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "QQBkAGQALQBBAHAAcAB4AFAAcgBvAHYAaQBzAGkAbwBuAGUAZABQAGEAYwBrAGEAZwBlACAALQBPAG4AbABpAG4AZQAgAC0AUABhAGMAawBhAGcAZQBQAGEAdABoACAAIgBNAFMAVABlAGEAbQBzAC0AeAA2ADQALgBtAHMAaQB4ACIAIAAtAFMAawBpAHAATABpAGMAZQBuAHMAZQA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : Élément introuvable._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\wapt\common.py", line 4234, in install_wapt
  File "C:\WINDOWS\TEMP\waptz0_us848\setup.py", line 22, in install
  File "C:\wapt\setuphelpers_windows.py", line 1198, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
Gälen
Nachrichten: 254
28. Februar 2024 - 08:19 Uhr
Der manuell ausgeführte Befehl liefert den Fehler, der im beigefügten Bild dargestellt ist.
– Installierte WAPT-Version (2.5.4.15342)
– Server-Betriebssystem (Linux/Windows) und Version (Debian 11)
– Betriebssystem des Administrations-/Paketerstellungsrechners (Windows 10).
Und noch eine Frage: Wie kann ich auf den Rechnern, auf denen die Installation funktioniert, eine Verknüpfung zu „Neue Teams“ auf dem Desktop hinzufügen oder den automatischen Start (im Hintergrund) einrichten?
Anlagen
2024-02-28 08_18_11.jpg (27,14 KB) 6715 Aufrufe
jpele
Nachrichten: 156
Anmeldung: 4. März 2019 - 12:01 Uhr
28. Februar 2024 – 16:02 Uhr
das Paket wurde gestern korrigiert und ist für 5 Tage im Test-Repository verfügbar, bevor es im öffentlichen Store veröffentlicht wird:
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Viele Grüße,
Jimmy
Gälen
Nachrichten: 254
29. Februar 2024 - 12:17 Uhr
Danke, Jimmy! Diese Version lässt sich tatsächlich fehlerfrei installieren. Jetzt muss ich nur noch herausfinden, wie ich Teams beim Systemstart automatisch starten kann, oder zumindest eine Desktopverknüpfung erstellen.
Nachrichten: 2026
29. Februar 2024 - 12:19 Uhr
Hallo Gaël,
danke für das Feedback. :-) Microsoft macht mit Teams momentan echt Probleme; wir haben Fälle gesehen, in denen fünf verschiedene Versionen auf demselben Rechner installiert waren… Die Bereitstellungsmethode ändert sich monatlich; es ist ziemlich chaotisch.
Beste Grüße,
Denis Cardon – Tranquil IT
