[GELÖST] Zulip Desktop-Client-Paket
vnatton
Nachrichten: 6
Anmeldung: 9. Januar 2024 – 13:53 Uhr
26. Februar 2024 – 14:56 Uhr
Hallo zusammen!
Ein kleines Codefragment zur Bereinigung der Installation und Aktualisierung des Zulip Desktop-Clients für Windows 64-Bit
Guten Tag
Vianney
    bin = "Zulip-%s-x64.msi" % control.get_software_version()
    install_msi_if_needed(bin)
    pass
def update_package():
    import json
    ancienne_version = control.get_software_version()
    # Declaring local variables
    package_updated = False
    proxies = get_proxies()
    if not proxies:
    api_url = "https://api.github.com/repos/zulip/zulip-desktop/releases/latest"
    # Getting latest version information from official sources
    print("API used is: %s" % api_url)
    json_load = json.loads(wgets(api_url, proxies=proxies))
    for download in json_load["assets"]:
        if "zulip-desktop" in download["browser_download_url"] and "-x64.msi" in download["browser_download_url"]:
            download_url = download["browser_download_url"]
            version = json_load["tag_name"].replace("v", "")
            latest_bin = download["name"]
            break
    # Downloading latest binaries
    print("Latest %s version is: %s" % (control.name, version))
    print("Download URL is: %s" % download_url)
    if not isfile(latest_bin):
        print("Binary is present: %s" % latest_bin)
    # Checking version from filename
    version_from_filename = latest_bin.split("-")[1]
    if Version(version_from_filename) != Version(version) and version_from_filename != "":
        print("Changing version to the version number of the binary")
        os.rename(latest_bin, latest_bin.replace(version, version_from_filename))
        version = version_from_filename
        print("Binary file version corresponds to online version")
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        package_updated = True
        print("Software version up-to-date (%s)" % Version(version))
    control.set_software_version(version)
    # Suppression de l'ancien binaire
    if isfile("Zulip-%s-x64.msi" % ancienne_version):
        os.remove("Zulip-%s-x64.msi" % ancienne_version)
    # Validating update-package-sources
    return package_updated
Nachrichten: 1954
29. Februar 2024 - 09:46 Uhr
Hallo Vianney,
vielen Dank für das Paket. Ingrid wird es sich ansehen und prüfen, ob sie es in den Shop integrieren kann. Es scheint ein vielversprechendes Tool zu sein; wir werden es intern testen. :-)
Beste Grüße,
Denis Cardon – Tranquil IT
italbot
Nachrichten: 70
Anmeldung: 26. September 2023 - 15:50 Uhr
7. März 2024 - 10:55 Uhr
das Paket ist fertig, Sie finden es in wenigen Tagen im Geschäft. :)
Mit freundlichen Grüßen,
Ingrid
Ruhige IT
