Seit heute Nachmittag tritt dieser Fehler auf mehreren Rechnern auf:
Get packages index from [<WaptRepo https://srvwapt.XXXXXX.local/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\heroult.XXXXXX.local.crt>, <WaptHostRepo https://srvwapt.XXXXXX.local/wapt-host for host_id heroult.XXXXXX.local >]
Max depth in build dependencies reached, aborting
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 923, in _run
self.result = self.wapt.update(force=self.force, register=self.notify_server_on_finish)
File "C:\Program Files (x86)\wapt\common.py", line 4874, in update
"upgrades": self.list_upgrade(),
File "C:\Program Files (x86)\wapt\common.py", line 5916, in list_upgrade
depends = self.check_depends(result['install']+result['upgrade']+result['additional'])
File "C:\Program Files (x86)\wapt\common.py", line 5039, in check_depends
(depends, conflicts, missing) = self.waptdb.build_depends([p[0] for p in packages])
File "C:\Program Files (x86)\wapt\common.py", line 1527, in build_depends
alldepends = dodepends(packages, depth)
File "C:\Program Files (x86)\wapt\common.py", line 1509, in dodepends
newdepends = dodepends(available_depends, depth+1)
[Previous line repeated 28 more times]
File "C:\Program Files (x86)\wapt\common.py", line 1484, in dodepends
raise Exception('Max depth in build dependencies reached, aborting')
Exception: Max depth in build dependencies reached, aborting
Aufrichtig,
Tom
