PostgreSQL jQuery-Fehler in den PostgreSQL-Protokollen
Antwort
Mikael S
Nachrichten: 27
Anmeldung: 20. Januar 2025 – 15:54 Uhr
3. Oktober 2025 – 8:11 Uhr
In den Datenbankprotokollen stieß ich auf Folgendes:
2025-10-02 23:59:27.817 CEST [1202] LOG:  starting PostgreSQL 15.14 (Debian 15.14-0+deb12u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv6 address "::1", port 5432
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv4 address "127.0.0.1", port 5432
2025-10-02 23:59:27.824 CEST [1202] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-10-02 23:59:27.856 CEST [1224] LOG:  database system was shut down at 2025-10-02 23:59:02 CEST
2025-10-02 23:59:27.888 CEST [1202] LOG:  database system is ready to accept connections
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt ERROR:  extension "jsquery" is not available
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt DETAIL:  Could not open extension control file "/usr/share/postgresql/15/extension/jsquery.control": No such file or directory.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt HINT:  The extension must first be installed on the system where PostgreSQL is running.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt STATEMENT:  CREATE EXTENSION if not exists jsquery;
2025-10-02 23:59:30.867 CEST [1794] wapt@wapt WARNING:  there is no transaction in progress
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt LOG:  could not send data to client: Broken pipe
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt STATEMENT:  COPY public.hostauditdata (id, host_id, value_id, value_date, value_section, value_key, value, expiration_date, created_on, created_by) TO stdout;
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt ERROR:  canceling statement due to user request
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt FATAL:  connection to client lost
Im Wiki wird die Notwendigkeit, das Paket postgresql-15-jsquery unter bookworm zu installieren, nicht erwähnt. Oder befindet es sich vielleicht auf einer anderen Seite? https://www.wapt.fr/en/doc/wapt-server- ... er-install
Aufrichtig,
Nachrichten: 1982
3. Oktober 2025 - 11:04 Uhr
Hallo Mickael,
die jQuery-Erweiterung wird für WAPT selbst nicht mehr benötigt. Bei einer Neuinstallation installiert das Postconf-Skript sie nur, wenn sie auf dem System vorhanden ist. Es stimmt jedoch, dass sie bei der Wiederherstellung eines Backups oder einer Serverneuinstallation Probleme verursachen kann. Diese Erweiterung kann in SQL/JSON-Abfragen verwendet werden.
Ich werde mit dem Team klären, ob wir sie während der Installation wieder in die Dokumentation aufnehmen oder eine bessere Möglichkeit finden können, sie bei einem Upgrade zu entfernen.
Viele Grüße,
Denis Cardon – Tranquil IT
Antwort
