[GELÖST] Audit-Pakete für LUKS und FileVault
Antwort
bastien30
Nachrichten: 38
Anmeldung: 8. März 2024 – 15:21 Uhr
7. Januar 2026 - 12:50 Uhr
Hier finden Sie Pakete zur Überprüfung der Verschlüsselung von Linux-Workstations mit LUKS und MacOS-Workstations mit FileVault.
LUKS:
    pass
def audit():
    audit_result = "OK"
    # Check existing LUKS partitions
    luks_partitions = run(r"lsblk -e7 -n -f -r -o NAME,FSTYPE | grep LUKS | awk '{print $1}'").strip().split("\n")
    if any(luks_partitions):
        # Ensure system partition is encrypted
        system_partition = None
        for luks_partition in luks_partitions:
            try:
                run(r"lsblk /dev/%s -l -o MOUNTPOINTS | grep '^/$'" % luks_partition)
            except:
                pass
                system_partition = luks_partition
                break
        if not system_partition:
            print(r'Error, system partition is not encrypted !')
            audit_result = "ERROR"
            # Ensure system partition is valid LUKS partition
            try:
                run(r'cryptsetup isLuks /dev/%s' % luks_partition)
            except:
                print(r'Error, system partition seems encrypted but is not a valid LUKS partition !')
                print(r'System partition is encrypted and is a valid LUKS partition')
        print(r'Error, cannot find any LUKS partition !')
    return audit_result
FileVault:
    pass
def audit():
    audit_result = "OK"
    filevault_status = run(r'sudo fdesetup status')
    if r'FileVault is On' in filevault_status:
        if r'Encryption in progress' in filevault_status:
            print(r'FileVault is enabled and encryption is in progress.')
            print(r'FileVault is enabled and disks are fully encrypted.')
    elif r'FileVault is Off' in filevault_status:
        if r'Decryption in progress' in filevault_status:
            print(r'FileVault is not enabled and decryption is in progress !')
            print(r'FileVault is not enabled and disks are not encrypted !')
        print(r'Cannot get FileVault status !')
    return audit_result
Antwort
