<!DOCTYPE html><html><body style="font-family:verdana"><h1>WAPTHttpServer Server Error 404</h1><hr><p>HTTP 404 Not Found</p><p>Wrong route</p><small>mORMot 2</small></body></html>Code: Alle auswählen
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 464, in _make_request
self._validate_conn(conn)
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 1093, in _validate_conn
conn.connect()
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 790, in connect
sock_and_verified = _ssl_wrap_socket_and_match_hostname(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 969, in _ssl_wrap_socket_and_match_hostname
ssl_sock = ssl_wrap_socket(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\ssl_.py", line 480, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls, server_hostname)
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\ssl_.py", line 524, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "ssl.py", line 513, in wrap_socket
File "ssl.py", line 1104, in _create
File "ssl.py", line 1375, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 787, in urlopen
response = self._make_request(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 488, in _make_request
raise new_e
urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)
The above exception was the direct cause of the following exception:
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 644, in send
resp = conn.urlopen(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 841, in urlopen
retries = retries.increment(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 519, in increment
raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='<fqdn du dépôt>', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)')))
File "<console>", line 1, in <module>
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 675, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='<fqdn du dépôt>', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)')))Code: Alle auswählen
x.x.x.x - - [02/Feb/2026:08:55:42 +0000] "HEAD /wapt/ping HTTP/1.1" 200 176 "https://<fqdn du dépôt>" "waptconsole/2.6.1.17472W"Code: Alle auswählen
import waptlicences
waptlicences.get_peer_cert_chain_from_server("https://reposecondaire",r"C:\waptdev\test")
AttributeError: module 'waptlicences' has no attribute 'get_peer_cert_chain_from_server'
