Ich versuche, ein Paket zu erstellen, um Cisco Webex auf meinen Workstations bereitzustellen.
In meiner Testumgebung funktioniert es.
Auf einem Rechner erhalte ich immer wieder diese Fehlermeldung:
installing: Webex.msi
Installing: Webex.msi (44.7.0.30285)
Waiting for key: {3F9B1AB5-2521-521E-8703-87D71A454DD7} to appear in Windows registry
File "C:\Program Files (x86)\wapt\common.py", line 4510, in install_wapt
File "C:\WINDOWS\TEMP\wapttcihpwwk\setup.py", line 16, in install
File "C:\Program Files (x86)\wapt\common.py", line 4427, in new_func
return func(*args, **kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1666, in install_msi_if_needed
error('MSI %s has been installed but the %s can not be found' % (msi,searchparam))
File "C:\Program Files (x86)\wapt\waptutils.py", line 2093, in error
waptutils.EWaptSetupException: Fatal error : MSI Webex.msi has been installed but the key {3F9B1AB5-2521-521E-8703-87D71A454DD7} can not be found
