Ich möchte die Software zur Bildgrößenänderung einsetzen.
dotnetfx4.0 ist korrekt installiert.
Hier sind die Fehlermeldungen, die ich finden konnte.
wapt-get install am-imageresizer
installing WAPT packages am-imageresizer
Installing am-imageresizer
Installing Image Resizer
2017-11-09 14:01:52,963 CRITICAL Package am-imageresizer not installed due to errors : Exception: The uninstall key: {6285B71F-660A-478B-A876-C7E66A678E6A} has not been found in system registry after software installation.
Results :
=== install packages ===
am-imageresizer | am-imageresizer (3.0.4802.35565-2)
=== skipped packages ===
am-dotnetfx4.0 | am-dotnetfx4.0 (4.0-6)
=== errors packages ===
am-imageresizer | am-imageresizer (3.0.4802.35565-2)Code: Alle auswählen
Exception: Error during install of am-imageresizer (=3.0.4802.35565-2): errors in packages [[u'am-imageresizer (=3.0.4802.35565-2)', PackageEntry('am-imageresizer','3.0.4802.35565-2')]]
File "c:\wapt\waptservice\waptservice.py", line 2100, in run
self.running_task.run()
File "c:\wapt\waptservice\waptservice.py", line 1360, in pwrapper
return func(*arg, **kwargs)
File "c:\wapt\waptservice\waptservice.py", line 1420, in run
self._run()
File "c:\wapt\waptservice\waptservice.py", line 1844, in _run
Exception: Error during install of am-imageresizer (=3.0.4802.35565-2): errors in packages [[u'am-imageresizer (=3.0.4802.35565-2)', PackageEntry('am-imageresizer','3.0.4802.35565-2')]]Haben Sie eine Lösung oder auch nur einen Ausgangspunkt?
Kommandant
