Zugang zum lokalen Geschäft
Gly
Nachrichten: 24
Anmeldung: 30. Mai 2019 - 11:45 Uhr
22. Februar 2022 – 17:08 Uhr
Hier sind die Fehlerprotokolle, die beim Zugriff auftreten https://urlduserverwapt/store (Fehler 500):
Feb 22 16:46:15 wapt waptserver[1097]: 2022-02-22 16:46:15,953 [waptserver.app ] ERROR Exception on /store/ [GET]
Feb 22 16:46:15 wapt waptserver[1097]: Traceback (most recent call last):
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
Feb 22 16:46:15 wapt waptserver[1097]:     cursor.execute(sql, params or ())
Feb 22 16:46:15 wapt waptserver[1097]: psycopg2.errors.UndefinedTable: ERREUR:  la relation « storedownload » n'existe pas
Feb 22 16:46:15 wapt waptserver[1097]: LINE 2:             LEFT JOIN StoreDownload
Feb 22 16:46:15 wapt waptserver[1097]:                               ^
Feb 22 16:46:15 wapt waptserver[1097]: During handling of the above exception, another exception occurred:
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/flask/app.py", line 2070, in wsgi_app
Feb 22 16:46:15 wapt waptserver[1097]:     response = self.full_dispatch_request()
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/flask/app.py", line 1515, in full_dispatch_request
Feb 22 16:46:15 wapt waptserver[1097]:     rv = self.handle_user_exception(e)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/flask/app.py", line 1513, in full_dispatch_request
Feb 22 16:46:15 wapt waptserver[1097]:     rv = self.dispatch_request()
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/flask/app.py", line 1499, in dispatch_request
Feb 22 16:46:15 wapt waptserver[1097]:     return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/waptserver/decorators.py", line 256, in decorated
Feb 22 16:46:15 wapt waptserver[1097]:     r = f(*args, **kwargs)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/waptserver/decorators.py", line 317, in decorated
Feb 22 16:46:15 wapt waptserver[1097]:     result = f(*args, **kwargs)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/waptserver/store.py", line 325, in packages
Feb 22 16:46:15 wapt waptserver[1097]:     packages = wapt_db.execute_sql(SQL)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3151, in execute_sql
Feb 22 16:46:15 wapt waptserver[1097]:     self.commit()
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2917, in __exit__
Feb 22 16:46:15 wapt waptserver[1097]:     reraise(new_type, new_type(exc_value, *exc_args), traceback)
Feb 22 16:46:15 wapt waptserver[1097]:   File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 190, in reraise
Feb 22 16:46:15 wapt waptserver[1097]:     raise value.with_traceback(tb)
Feb 22 16:46:15 wapt waptserver[1097]: peewee.ProgrammingError: ERREUR:  la relation « storedownload » n'existe pas
Haben Sie eine Idee, woran das liegen könnte? Zur Information: Ich habe den Parameter `enable_store=true` aktiviert
Vielen Dank
Nachrichten: 1953
3. März 2022 – 16:40 Uhr
Hallo Gly,
dieser Abschnitt ist nicht besonders hervorgehoben und wir hatten geplant, ihn zu entfernen. Nutzt du ihn intern? Wofür?
Ich glaube, der betreffende Fehler wurde in Version 2.2 behoben, aber ich weiß nicht, ob er in Version 2.3 noch vorhanden ist oder ob er zumindest nicht mehr direkt in das waptserver-Paket integriert wird (d. h., er könnte in ein externes Skript ausgelagert werden).
Viele Grüße,
Denis Cardon – Tranquil IT
Gly
Nachrichten: 24
7. März 2022 - 10:29 Uhr
Ich suche nach einer Möglichkeit, meine Paketliste mit Kollegen anderer Institutionen (die über einen eigenen WAPT-Server verfügen) zu teilen.
Anstatt dass jeder isoliert seine eigenen Pakete entwickelt, insbesondere für gängige Geschäftsanwendungen, wäre es viel besser, diese einfach einsehen und herunterladen zu können.
Eine Lösung wie diese hier schien ideal: https://wapt.lesfourmisduweb.org/tous-les-packages.
Vielen Dank im Voraus für jeden Lösungsvorschlag.
Nachrichten: 1953
25. März 2022 – 16:33 Uhr
Hallo Gly,
ich frage Simon, ob es möglich wäre, den PHP-Code aus dem WAPT-Repository der Ameisen auf GitHub hochzuladen.
Viele Grüße,
