Page 1 of 1
[SOLVED] Missing dependencies error
Published: September 27, 2022 - 09:44
by gauthier_leclercq
When I add the adobereader package from the Tranquil'IT repository to my package group, I get the error "Missing dependencies" (see attached image).
If I add the package to the self-service package manager, the self-service package updates, but the adobereader package is still not available on the user's machine.
Do you know what might be causing this?
Thank you.
Gauthier.
- WAPT version installed: 2.1.2
- Server OS: Debian Buster
Re: [WAPT] - Missing dependencies error
Published: September 27, 2022 - 10:02 AM
by dcardon
If you do have an adv-adobereader package in your repository, you should check its compatibility with your machine's capabilities (maturity, language, architecture (32-bit vs. 64-bit), etc.). A fairly common problem is having a 32-bit Windows machine and only having a 64-bit package.
Regards,
Published: September 28, 2022 - 3:05 PM
by benoitpatin
Hi Denis,
We don't have 32-bit Windows here.
Any other ideas?
Thanks
Published: September 28, 2022 - 3:54 PM
by dcardon
Is the downloaded package the 64-bit package for Windows? Is the agent up to date? Is it properly imported into production (or at the correct maturity level)?
We're going to implement a graphical method to determine why a package matches or doesn't match on a given machine. But for now, we need to check the different capabilities individually.
Published: September 29, 2022 - 12:01
Yes, I confirm the machine is a 64-bit machine.
Is the downloaded package the 64-bit package for Windows? Yes, Arch in All (see attached image).
Is the agent up to date? Yes, version 2.1.2.10652.
Is it properly imported into production (or at the correct maturity level)? Yes, imported into production.
Gauthier.
Published: October 6, 2022 - 10:40 AM
by dcardon
Were you able to resolve the capacity matching issue?
Regards,
Published: November 14, 2022 - 4:29 PM
by smandel
I had the same problem with Adobe on several machines.
After setting the "Target Architecture" to "x64" in the packages and downloading the "x64" version of Adobe, there were no more problems.
Published: November 15, 2022 - 2:36 PM
by dcardon
Okay, thanks for the feedback, Stany! I'm marking this as resolved.
