Page 1 of 1
[SOLVED] Create a query
Published: August 11, 2026 - 3:55 PM
by Catherine
I've never created a query in Reporting before.
I'd like to create a "Cortex" query to find out which PCs have a Cortex version prior to 9.0.0.
Could you please help me?
Thank you for your help.
Re: Create a query
Published: August 11, 2026 - 4:20 PM
by Jarnaud
No problem, here's how:
1. Create the query
In the WAPT console, go to Reporting → Design Mode → New Query. This adds an empty query that you can then edit and rename (F2 key).
2. The SQL query
Based on the example "Listing hosts with their 7zip installed" (which uses the hostsoftwares table joined to hosts), here is a query adapted for Cortex:
SQL
select
    h.uuid,
    h.computer_name,
    s.version,
    s.install_date::date
from hostsoftwares s
left join hosts h on h.uuid = s.host_id
where
    s.name ilike '%cortex%'
    and string_to_array(s.version, '.')::int[] < string_to_array('9.0.0', '.')::int[]
For your information, all the documentation related to reporting is here: https://www.wapt.fr/fr/doc/wapt-console ... rting.html
Yours sincerely
Re: Create a query
Published: August 12, 2026 - 07:45
by Catherine
Thank you very much.
I just tried it and I got an error message: "error on server: IndexError ('tuple index out of range')".
What does that mean?
Regards.
Re: Create a query
Published: August 12, 2026 - 09:23
by Jarnaud
This means that an index (a position) in a tuple (or a list) does not exist.
Try again with this request:
SELECT hostsoftwares.version,
       hostsoftwares.name,
       hosts.computer_name,
       hostsoftwares.host_id
FROM hosts, hostsoftwares
WHERE hostsoftwares.name ILIKE 'Cortex%%'
  AND hosts.uuid = hostsoftwares.host_id
  AND string_to_array(hostsoftwares.version, '.')::integer[] < ARRAY[9,0,0]
ORDER BY hosts.computer_name ASC
Yours sincerely
Re: Create a query
Published: August 12, 2026 - 10:10
by Catherine
Great, :D :D :D
thank you so much! :D :D
Quick question: if Cortex updates, will re-executing the query change the result?
Thank you very much
Have a lovely day.
Sincerely.
Re: Create a query
Published: August 12, 2026 - 10:59
by Jarnaud
Yes, a query displays results at a specific point in time (its execution).
If machines update Cortex to a version higher than 9 in the meantime, then those updates will no longer be displayed in the query results.
Best regards.
