I've never created a query in Reporting before.
I'd like to create a "Cortex" query to find out which PCs have a Cortex version prior to 9.0.0.
Could you please help me?
Thank you for your help.
[SOLVED] Create a query
No problem, here's how:
1. Create the query
In the WAPT console, go to Reporting → Design Mode → New Query. This adds an empty query that you can then edit and rename (F2 key).
2. The SQL query
Based on the example "Listing hosts with their 7zip installed" (which uses the hostsoftwares table joined to hosts), here is a query adapted for Cortex:
SQL
For your information, all the documentation related to reporting is here: https://www.wapt.fr/fr/doc/wapt-console ... rting.html
Yours sincerely
1. Create the query
2. The SQL query
SQL
select
h.uuid,
h.computer_name,
s.version,
s.install_date::date
from hostsoftwares s
left join hosts h on h.uuid = s.host_id
where
s.name ilike '%cortex%'
and string_to_array(s.version, '.')::int[] < string_to_array('9.0.0', '.')::int[]Yours sincerely
This means that an index (a position) in a tuple (or a list) does not exist.
Try again with this request:
Yours sincerely
SELECT hostsoftwares.version,
hostsoftwares.name,
hosts.computer_name,
hostsoftwares.host_id
FROM hosts, hostsoftwares
WHERE hostsoftwares.name ILIKE 'Cortex%%'
AND hosts.uuid = hostsoftwares.host_id
AND string_to_array(hostsoftwares.version, '.')::integer[] < ARRAY[9,0,0]
ORDER BY hosts.computer_name ASCYours sincerely
